ST170 dash clocks fitting
Old Nov 27, 2010 | 11:18 PM
focus 4x4's Avatar
focus 4x4
Default ST170 dash clocks fitting
Hi , im aware that upgrading to an st170 dash/clocks from a standard Mk1 focus dash is a stright swap , no problems but ive been told that getting them to light up at night properly is an issue?
Any done this mod??
Old Nov 27, 2010 | 11:21 PM
chris cdti's Avatar
chris cdti
IIRC you need the oil pressure pod aswell as the dials then run the power from the oil pressure pod to the wires on the top of the dials
Old Nov 27, 2010 | 11:52 PM
focus 4x4's Avatar
focus 4x4
yeah thats been mentioned too!
Old Nov 27, 2010 | 11:54 PM
chris cdti's Avatar
chris cdti
Yeah one of the lads in work done it on his TDCI Sport. This was the only way the dials would light up, by doing this. Everythng else worked as normal from the multi plug behind the dials.
Old Nov 28, 2010 | 12:27 PM
focus 4x4's Avatar
focus 4x4
Yeah theres something in the oil pressure pod the lights up the dash - so ive read somewhere. be good to see if anyones done this to a non ST170 .
Old Nov 28, 2010 | 06:10 PM
focus 4x4's Avatar
focus 4x4
Apparently .............
The oil gauge pod contains the inverter to power the electroluminescent dials of the ST170 (the whole face lights up, not just the numbers) so you would need this or a separate inverter.
Old Nov 28, 2010 | 08:59 PM
focus 4x4's Avatar
focus 4x4
Found this thread aswell , so hopefully my theory will prove me right .... fingers crossed lol
http://www.focusowners.com/forum/viewtopic.php?t=31215
Old Nov 28, 2010 | 09:12 PM
RichieST's Avatar
RichieST
Yes you need the oil pod as this contains the inverter for the backlit guages. You won't be able to get the oil guages to work though as they are pulse driven direct from the ECU, its not just a case of bolting in a new sender unit!
Old Nov 28, 2010 | 09:25 PM
focus 4x4's Avatar
focus 4x4
Thats cool because i dont want to use the oil gauges , ill connect the inverter directly to the ST170 back light dials and power them that way , missing out the Oil gauges all together.
Old Nov 29, 2010 | 11:12 AM
Davemurphy007's Avatar
Davemurphy007
Ford Focus Specialist
You can run a seperate inverter to power the ST170 dials.
A Focus ESP I took possession of earlier this year did exactly that as he had a trip computer where the ST170 oil pod would have gone.
Old Feb 28, 2016 | 01:19 PM
Connect Jay's Avatar
Connect Jay
I have the oil clocks but no idea how to wire them up to power the inverter for dash lights? Anyone give me some clues on wiring it up just to power up the inverter please
Kyle Langford
27
Aug 5, 2019 07:54 PM
Oct 9, 2015 07:38 PM
track.focus'd
Aug 12, 2015 05:53 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
