Mondeo drive shaft
Old Nov 21, 2010 | 12:28 PM
Mull XR's Avatar
Mull XR
Default Mondeo drive shaft
Helping a mate do the bottom arms on his mk2 mondeo. Got everything bolted back together. Car stll on stands. When we put it in gear the driver wheel is spinning. Have I pulled the shaft out of the gearbox?
Old Nov 21, 2010 | 03:23 PM
owenglen's Avatar
owenglen
under the bonnet
try and hold the spining wheel it sounds like the diff is just putting power thought that. hold it and the other should spin
Old Nov 21, 2010 | 11:55 PM
Mull XR's Avatar
Mull XR
I don't think I made it easy to understand. I ment when in gear with the engine off the driver wheel would spin but passager side wouldn't. I thought both wouldn't. I've took it for a drive before and all is well. Thanks
Old Nov 22, 2010 | 12:11 AM
phil_focus's Avatar
phil_focus
open diff so power is sent to the wheel thats easiest to spin (has less grip). on axel stands if one brake slightly binds more than the other then the side with less binding will spin.
Old Nov 22, 2010 | 12:36 PM
+1
Old Nov 22, 2010 | 04:59 PM
owenglen's Avatar
owenglen
under the bonnet
is that right phil f lol
Old Nov 22, 2010 | 05:10 PM
phil_focus's Avatar
phil_focus
no its not, i lied. its complete and utter crap lol.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
TPM961
Jan 15, 2018 10:50 AM
tib2220
Sep 14, 2015 12:33 PM
Bransby
Sep 11, 2015 09:12 PM
rsstav
Sep 7, 2015 04:43 AM
