Cosworth Running Problems
Old Nov 18, 2010 | 01:05 AM
PETESTURBO's Avatar
PETESTURBO
Default Cosworth Running Problems
Hi I need help please.
I have a 4x4 cosworth engine.
The car runs fine all through the rev range with medium throttle.
When on full throttle and full boost, when the car reaches about 6500 revs the engine will cut out and will not respond at all - the ignition lights do not light up.
When the engine drops below appx 2500 revs the engine will then respond but will not go above 3000 revs without cutting out again.
At this point when the car is stationary when a steady half throttle is applied the engine will rev up and down from normal idle to 3000 revs. up, down, up ,down etc.
If the engine is then turned off for about 5 mins everything returns to normal until giving it full throttle again.
P.S it is not Limp Home Mode.
Any ideas will bit greatly appreciated.
Cheers Pete
Old Nov 18, 2010 | 06:18 AM
I'd get a fuelling check done asap, if not sooner, after a pump rewire and fuel filter change.
I'd also avoid at all costs giving it death until the check as a very minimum has been done.
Old Nov 18, 2010 | 10:06 AM
PETESTURBO's Avatar
PETESTURBO
Thanks for your reply Tabetha.
Bit of an update, the car is running fine now but after some rectification work.
1) I found both the loom plugs wet and full of green shit.
2) I found that the fault only occured on max throttle only. (Any revs)
The loom plugs have been cleaned thoroughly with electrical contact cleaner.
I have disconneccted the TPS and now the car runs brilliantly.
My questions are now -
What function does the TPS serve and is it safe to run the car with it disconnected?
Regards
Pete
Old Nov 18, 2010 | 03:17 PM
martysmartie's Avatar
martysmartie
The TPS (Throttle Position Sensor) informs the ECU of the throttle angle and from this info engine load can be determined. One example is shutting off fuel on the overrun if the throttle is closed and so better economy as a result. It does obviously need the sensor I am surprised to hear you say it runs 'brilliantly' does it not hesitate at all or anything?
Martin
Old Nov 19, 2010 | 12:36 AM
PETESTURBO's Avatar
PETESTURBO
Thanks for your reply Marty.
Update number 2 - After removing the TPS sensor the car fine until the engine become hot then it would not go over 4000 revs so the TPS sensor was reconnected.
Now I'm back to square one with the car cutting out at max throttle only.
I couldn't understand why the car started to do this but I have found out why now.
Originally the car would never achieve max throttle because the accelerator cable had been adjusted so that it only operated the throttle houseing arm to 95% of its movement hence why max throttle had never been possible. (By others?)
When I serviced the car I had adjusted the throttle cable correctly so that throttle houseing arm would now travel 100% of it movement and would now acheive max throttle.
This is when the problems started!
I have now wound the accelerator cable back so that the throttle houseing arm only just does not reach max movement and the car drives fine and strong just like it used to.
Now I have to find out what is causing the engine to cut out at 100% throttle movement?
Has anyone had this problem before?
Regards Pete.
Old Nov 20, 2010 | 05:08 PM
robvirgo's Avatar
robvirgo
might need the tps resetting, you have to loosen bolts and rotate so you just start to feel spring resistance...thats it as far as i remember.must do it it on a car i have here next week tho.
Old Nov 21, 2010 | 04:39 PM
forevaford's Avatar
forevaford
i had a similar problem with my 4x4 saph, it was the 2 engine loom multiplugs on the bulkhead by rocker cover. chopped these out and soldered now fts fine
manuel boeckx
13
Oct 3, 2015 02:29 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
