Fiesta RS Turbo Beige Injectors
Old Nov 10, 2010 | 11:52 AM
Rogeyboy's Avatar
Rogeyboy
Default Fiesta RS Turbo Beige Injectors
Im about to install my 165 superchip into my FRST Engine, i have a set of beiges and an adjustable fuel pressure regulator. Could i put the beiges in and just turn the fuel pressure down slightly while its on the 165 chip?
Old Nov 10, 2010 | 02:17 PM
martysmartie's Avatar
martysmartie
No, you need the correct injectors the chip is mapped for.
Martin
Old Nov 10, 2010 | 02:31 PM
chaffe's Avatar
chaffe
Turbocharging Technician
what cc/min difference is there in the injectors?
Old Nov 10, 2010 | 02:47 PM
rst cabbie's Avatar
rst cabbie
gingeRS cabriolet
you need a 195 chip for beiges other wise it will over fuel a 165 chip is designed for blue injectors and standard fuel pressure
Old Nov 10, 2010 | 02:49 PM
chaffe's Avatar
chaffe
yes at three bar fuel pressure, but he is correct in thinking you can turn the fuel pressure down to say 2.5 bar, What cc/min are blues and what cc/min are beiges?
Old Nov 10, 2010 | 05:26 PM
martysmartie
I disagree, even with the fuel pressure lowered you still need the correct injectors as the mapping will be totally different.
Martin
Old Nov 11, 2010 | 07:16 AM
chaffe's Avatar
chaffe
Is it not just a temporary measure until the correct chip is sourced? just megasquirt it, saves a lot of fannying about
Old Nov 12, 2010 | 12:10 PM
Rogeyboy's Avatar
Rogeyboy
If i fit the beiges i will have them inplace with the 165/stage 1 chip for around a year before i upgrade to 195/stage2. I have an adjustable fuel pressure regulator and would turn the pressure down (get it tested/setup professionally) so the beiges wouldnt throw so much fuel in.
I just have a brand new set of beiges and was wondering if i could use em. Save getting my blues cleaned/refurbed...?
Old Nov 12, 2010 | 12:11 PM
Rogeyboy's Avatar
Rogeyboy
Also what is the standard fuel pressure for a Fiesta RS Turbo?
Old Nov 12, 2010 | 12:46 PM
chaffe's Avatar
chaffe
but then you would have absolutly no advantage for fitting the injectors
Old Nov 14, 2010 | 09:56 PM
Rogeyboy's Avatar
Rogeyboy
Other than theyd be 100% equal flowing and theyd be in place ready for the 195 chip...
Old Nov 14, 2010 | 10:09 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Why not just Fit the chip and leave the standard injectors in???
Old Nov 15, 2010 | 07:09 AM
chaffe's Avatar
chaffe
Not sure i get what you mean? 100 percent equal flowing?? all injectors will flow equally in the same rail? plus if you waited until you got the chip it would take ten mins to change the injectors, its a really easy job, and it would save fucking your engine by bore washing it with a rich mixture for the next few months. It has no advantage to use higher flow rate injectors and then effectivly derate them by turning the pressure down, effectivly making them the same flow rate as the originals, it gives you no more overhead of fuel and no performace advantage.
Old Nov 15, 2010 | 07:10 AM
chaffe's Avatar
chaffe
That would lean it off, as a chip designed for bigger injectors will have a smaller pulswidth than one for smaller injectors, therefore the car will be leaner accross the board.
Old Nov 15, 2010 | 10:14 AM
Rogeyboy's Avatar
Rogeyboy
20yr old injectors aren't gonna flow evenly across all 4 in the same rail/car as they are all carboned up differently. The beiges i have r brand new and will fuel equally... Thought it'd make it run nicer thats all...
If theres no advantage and it might damage my beiges i won't bother, until i get the right chip for them.
Do you know if Fiesta RST Blues are the same as XR2i blues? The numbers on them are the same... Also are the fuel pumps the same?
Old Nov 15, 2010 | 11:20 AM
martysmartie
Use the right injectors for the chip, can't say about the injectors but I should think from what you have said there the same but can't say either way, I should think the fuel pump is different.
No advantage what so ever with the beiges with the chip, the mapping is totally different as said re the pulse widths so will do more harm then good.
Not sure on the standard fuel pressure, that's assuming of course your remapped chip is written for standard fuel pressure, usually they are but some are not!
Martin
Old Nov 15, 2010 | 11:40 AM
chaffe's Avatar
chaffe
of course they are the same, same bosch part number.
Old Dec 4, 2010 | 02:03 PM
germanfrstdriver's Avatar
germanfrstdriver
3dr moonstone cossi
the beige fueling is to rich with a 165 chip.
use the genuine blue ones.
Old Mar 29, 2013 | 07:51 PM
clarke5700's Avatar
clarke5700
But the 165 chip is designed for blue injectors!!
Old Mar 29, 2013 | 07:54 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Standard fuel pressure is 3 bar
You need a 165 chip for blue injectors
and a 195 chip/Motorsport Developments custom chip for beige injectors
Do it properly once.
Old Mar 31, 2013 | 12:08 PM
Ben26's Avatar
Ben26
yea u slaaaaaaaaaaaaaag do it properly
also
All fiesta turbos have an adjustable fuel reg BTW
Old Nov 22, 2013 | 09:05 AM
mattxr2's Avatar
mattxr2
Just seen this thread and I need a 195 chip myself as iv just converted my mk2 fiesta from mfi turbo to efi and I have beiges???? I was wondering if anyone had 1 knocking about they would like to sell
paceo
Feb 3, 2016 10:31 AM
carlo
24
Oct 5, 2015 08:20 PM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
knight19770
Aug 4, 2015 12:36 PM
