2.0 litre escort mk6?
Old Nov 10, 2010 | 11:40 AM
alexno1dj's Avatar
alexno1dj
Default 2.0 litre escort mk6?
hi people, im doing a conversion on an escort from 1.6 to 2litre. Silvertop , im aware that ill need to change sump, and water pump on the 2 litre for 1.6 items. is there anything else i have missed and can anyone give me a quick guide on it
cheers people
Old Nov 10, 2010 | 12:22 PM
phil_focus's Avatar
phil_focus
i think its
sump
oil pickup pipe
water pump as they rotate the opposite way on the 2l (might be a case of swapping over all your anciliaries onto the 2l i cant remember)
1.6 or 1.8 flywheel and clutch.
then you'll need the modeo ecu, one of a couple of codes and a fairly simple rewire of the connector.
if you go onto www.feoc-uk.com i think theres a how to on there. if not theres a few people on there who have done this conversion a few times.
Old Nov 10, 2010 | 02:26 PM
alexno1dj's Avatar
alexno1dj
Originally Posted by phil_focus
i think its
sump
oil pickup pipe
ok thanks mate, might go down the 130 spec 1.8 route now as ones come up at a decent price
Old Nov 10, 2010 | 07:20 PM
phil_focus's Avatar
phil_focus
seriously mate i'd go 2l!
135 bhp for the same money as buying cams and throttle body (if you look around) and more torque than the 1.8. then you;ve got the increased modability of the 2l as 4-2-1 manifold, decat, cat back and pannel filter should see upto 150 bhp.
Old Nov 10, 2010 | 07:44 PM
alexno1dj's Avatar
alexno1dj
hmm thats true mate,
to start with can i use my 1.6 flywheel, clutch and IB5 box? also can i retain std manifold and downpipe. been looking at a few 2litres now
Old Nov 10, 2010 | 07:50 PM
phil_focus's Avatar
phil_focus
yes you will have to use the 1.6 flywheel and clutch and you can keep your box.
you might have to use the 2l exhaust manifold. i hink you need the 2l inlet manifold aswell.
get yourself onto feoc, they will help you every step.
Old Nov 10, 2010 | 07:57 PM
alexno1dj's Avatar
alexno1dj
thanks mate
Vincereese
Jun 1, 2023 09:14 AM
Kyle Langford
27
Aug 5, 2019 07:54 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
