engine/gearbox mounts
Old Nov 2, 2010 | 09:47 PM
patton16i's Avatar
patton16i
Back in business
Default engine/gearbox mounts
Hi im currently restoring my mk3 escort rs 1600i,im putting a zetec engine in it,am i correct in thinking that a standard rsturbo gaearbox will bolt straight onto the zetec engine,so the gearrbox side mounts will remain the same?will i need to manufacture a zetec to mk3 engine mount or is there a far easier method?id realy appreciate your help as this is my main hold up.
Old Nov 3, 2010 | 10:15 AM
mobb-black's Avatar
mobb-black
weld a piece of bar onto the drivers side wing and drill it to accept the Zetec mount
Old Nov 3, 2010 | 10:47 AM
chaffe's Avatar
chaffe
Turbocharging Technician
the cvh mounts bolt onto the block of the zetec, should be three bolts but only two line up, this is no problem. The gearbox bolts onto the block also, so no problem there, only problem you might have is the 2 litre flywheel doesnt fit inside your box and you will have to use a 1.8 item. hope this helps
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Andypandy260
Sep 23, 2015 10:28 PM
