speedo problem
Old Nov 1, 2010 | 11:05 PM
MARKYMARKONE's Avatar
MARKYMARKONE
Default speedo problem
hi
my brother has a 1990 s2 turbo which has a strange problem with the speedo, when accelerating the speedo goes up as it should but when you back off or change gear the needle goes up and down like a rev counter.
so far weve changed the cable and tried a different speedo head with no luck, then we took out the speedo drive which was worn so we replaced that with a new one and all was good for a day or 2 and then it starts playing about again, i took the drive out again and its worn this again.
has anybody got any ideas as im lost what to try now
cheers
mark
Old Nov 2, 2010 | 08:14 AM
Pretty sure it is the diff support bearings worn that cause this on these models, applying throttle then backing is loading and unloading the box/diff and a small amount of play in diff support bearings can do this.
Old Nov 2, 2010 | 08:24 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Another bc box bites the dust
Old Nov 3, 2010 | 07:31 PM
MARKYMARKONE
hi tabetha
thats what i didnt want to hear, it looks like rebuild time
cheers
mark
DAZZER
Sep 30, 2015 08:43 PM
cossie brad
Sep 29, 2015 02:38 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
