what size wheels whith the 30mm eibach springs
Old Oct 27, 2010 | 02:15 PM
sykes2009's Avatar
sykes2009
Default what size wheels whith the 30mm eibach springs
what size wheels should i go for if i use the 30mm eibach springs i don't want it to look like a monster truck and i don't want to go any lower as the speed bumps around here are mahoosive i have seen a focus with 18" on and has not been lowered and it looked shite
Old Oct 27, 2010 | 03:12 PM
sykes2009's Avatar
sykes2009
looking at the focus mk1 threads 17" seem acceptable with the 30mm eibach springs but i have a mk2 and things maby different i don't no witch way around to do things suspension 1st then alloys or other way around
Old Oct 27, 2010 | 03:27 PM
SteveB's Avatar
SteveB
My misses mk2 on 18" and Eibach springs
Old Oct 27, 2010 | 03:42 PM
sykes2009's Avatar
sykes2009
thank you for that it dosent look as bad as i thought it would im still stuck beetween 17" and 18" and i have had this problem for the last 11 month's i keep changing my mind i really dont no witch way to go do they rub at all allso whats the width of the wheels and offset
thank you the picture really helps
Old Oct 27, 2010 | 04:30 PM
thebigmacmoomin's Avatar
thebigmacmoomin
My ST lowered on Eibachs'.
Backs a little high for my likeing but ok if I carry a spare wheel all the time.
Old Oct 27, 2010 | 05:28 PM
sykes2009's Avatar
sykes2009
yeah that looks nice too cheers for the picture for 18" i was thinking some ronal areo's if i go for 17" it would be some black or white pro race 3's i have said before that the st wheels are a big option but i want to be different but i could be different with the st wheels by changing the colour but when i used a offset calculator they didnt fit as good as some other alloys i had seen so on what to do really
Old Oct 27, 2010 | 05:30 PM
sykes2009's Avatar
sykes2009
and i like the look of the second pic them alloys seem to suit your car better than the st ones
Old Oct 27, 2010 | 05:57 PM
SteveB's Avatar
SteveB
ET42 7.5"x18" on 225/40 tyres no rubbing at all....IMO with the price of 18's and 18" tyres now I'd defi go 18's, I think if your going to go 17" you need to go real low on the suspension.
Steve
Old Oct 27, 2010 | 06:02 PM
sykes2009's Avatar
sykes2009
thank you for the help
Old Oct 28, 2010 | 03:35 PM
sykes2009's Avatar
sykes2009
can i ask what the wheels are steveb
and yours in the second pic thebigmacmoomin
cheers
Old Oct 28, 2010 | 06:25 PM
thebigmacmoomin
Mine are Kei Force 10's in 18".
These are the same wheels but on a normal Focus lowered on Eibachs.
17" look too small on a Mk2 Focus.
Old Oct 28, 2010 | 07:09 PM
sykes2009's Avatar
sykes2009
thank you thebigmacmoomin yeah i have looked around abit and its defiantly going to be 18" just having a look at what wheels i like and what will fit
Old Oct 29, 2010 | 07:08 AM
SteveB's Avatar
SteveB
MK2 Focus RS copies in 18" instead of 19"
Old Oct 29, 2010 | 08:45 AM
sykes2009's Avatar
sykes2009
thank you ^^^
Old Oct 30, 2010 | 02:15 PM
sykes2009's Avatar
sykes2009
what do you think of these
http://www.wheelbasealloys.com/18_In...res__P1206_346
Old Nov 9, 2010 | 05:52 PM
sykes2009's Avatar
sykes2009
i got the springs yesterday, my brother in law said he can get them fitted for Ł60 but he doesn't think that the axle alinement can be done is it necessarie im i even right in saying that it needs doing its what i read off the paper that came with the springs
Old Nov 9, 2010 | 05:56 PM
jammerrs's Avatar
jammerrs
lower it first, nowt worse than a tractor
id go 18's personally
and yeah ypud be better off checking the tracking when its lowered as it can affect the camber and toe etc, an additional expensive but its better than scrubbing tyres
Old Nov 9, 2010 | 06:30 PM
sykes2009's Avatar
sykes2009
^^^ cheers, yeah im going to lower it first looks like i will have to find somebody else to do it how much do you reckon it will be for springs fitted and alignment,camber checked ect
Old Nov 9, 2010 | 06:34 PM
sykes2009's Avatar
sykes2009
its going to be 18" for deff its just picking some wheels and sticking to them to many to pick from i have found some more since the team dynamic ones
Old Nov 10, 2010 | 01:27 PM
Sp3no's Avatar
Sp3no
I had my rear blade suspension re aligned after fitting eibach springs its easily done on a 3d laser alignment machine, the BIG issue is that the ecentric bolts that are used to adjust the camber are very exposed to the elements and as such they seize up completely so if turned they end up ripping the lower track control arm bushing away from its casing. Your also meant to set the design ride height by loosening the lower track control arm bolts but these seize up also.
When i first fitted the springs the above happened when i tried to adjust the camber and set the ride height and it ended up with me dropping the rear suspension off the car completely and re-building it with new bolts, braided hoses, Poly bushes and having the lot painted and powder coated at a HUGE cost.
If you dont set the ride height then it puts extra twist on the track control arm bushes and they eventually rip away from the outer bush casing.
Old Nov 10, 2010 | 05:43 PM
sykes2009's Avatar
sykes2009
^^^^ uh oh that dosent sound good but im abit stupid i dont full understand
dose it mean it carnt be done, or can i only get it done in a certain way
Old Nov 10, 2010 | 05:49 PM
sykes2009's Avatar
sykes2009
it really sounds like a ballach i dint think it would be so much trouble
Old Nov 11, 2010 | 12:32 PM
Sp3no's Avatar
Sp3no
when the suspension arm moves it twists the bushing which is fine in standard form, thats one of the jobs of a bush. When you lower the car this puts extra strain or twist on the bushes so that over a short time they will wear out or delaminate from the outer casing, when you set the ride height you loosen the bolts that go through the bush's, lower the car to the ground till you achieve the correct clearance between bottom lower conrol arm and bottom of sub frame then tourqe them back up, this sets the position in suspension travel that strains the bush back to an acceptable stage. One of these bolts is ecentric with an ecentric washer on the rear, as you turn it the lower control arm is pushed out or in to adjust camber, if seized you cannot do this.
This is the propper way of doing it, the other way is to pry bar the rear arms down to drop the springs out then stick the new ones in and leave it like that but the geometry will be wrong and the bushes wont last long.
You hae a MK2 so chances are you will be able to undo the bolts no problem so you wont have to worry about anything i mentioned lol
Old Nov 11, 2010 | 05:49 PM
sykes2009's Avatar
sykes2009
thank you for explaining it to me if i have the option i would like to do it the correct way,or the best way
i dont suppose it will but could it help if i keep spraying some wd40 for a few days before it would get done
SmudgerByName
52
Jul 28, 2016 06:14 PM
3drRich
Sep 13, 2015 07:32 PM
borboyous
Aug 22, 2015 11:17 AM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
