pic request :- rusty floors UPDATE stripped interior out pics inside!
Old Oct 26, 2010 | 05:22 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Default pic request :- rusty floors UPDATE stripped interior out pics inside!
bit of a strange one i know but just wondered if people have pics of rot they have found on there floors and reapired, i ask as ive just found a few holes on my saffs floor im totally devo but been told its not actually bad just want to see what otheres have repaired to put my mind at ease lol
Old Oct 26, 2010 | 05:28 PM
vaughant's Avatar
vaughant
It's very common on saphs,don't worry too much about that mate.common points are seat belt mounts,inner kick plates,jacking points and floorpans themselves.I may have q few of my underside welding so I'll put them up.....I hope your rear chassis legs are ok,their a twat to do!
Old Oct 26, 2010 | 05:37 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
i was hoovering it yesterday when i lifted the mat in my drivers side footwell it was absouletly soaking so i lifted the carpet and its all turned brown rusty where the rest is still white i found a hole the size of a 5p lol and then theres like 3 slits??? havent checked anywhere else yet im pulling the interior out on the weakend see whats what just gutted
Old Oct 26, 2010 | 05:45 PM
vaughant's Avatar
vaughant
Shove a photo up fella,it maybe a grommit or something?
Old Oct 26, 2010 | 05:47 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
its where the floor meets the sill if that makes sence and the slits are under the peddles where the floor starts to slope up, ill get some piccys tomorow when its light lol
Old Oct 26, 2010 | 07:18 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
yeah a mate told me it could be a gromit for the clutch cable missing
Old Oct 26, 2010 | 08:15 PM
cosmatt's Avatar
cosmatt
my rs2000 cosworth. This should make you feel better lol
Old Oct 26, 2010 | 08:20 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
lol yeah cant say mines that bad lol i guess mine would defo be repairable lol
Old Oct 26, 2010 | 08:22 PM
phil_focus's Avatar
phil_focus
haha.
get some pics up of your rust mate.
Old Oct 27, 2010 | 04:41 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
few pics thats just my drivers footwell stripping the seats/carpet out on the weakend to try and find more is it bad or not ??
Old Oct 27, 2010 | 05:05 PM
155lee's Avatar
155lee
somebodys spoofed that up already.i just finished welding mine up.it had a couple of holes where the sill meets the floor.the best thig you can do is get in with the grinder with the wire wheel and a screwdriver and poke and grind till your happy you have found all the rot.mine wasnt bad,where the raised bit behind the jack locating hole is was gone so i cut all that out and welded in a plate.its under the pedals where the grills are.its best not covering rot,cut out as much as you can then make plates up.its a shitty job but once its done and all solid again its worth it!
i didnt take any pics tho!
Old Oct 27, 2010 | 05:18 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
cheers mate ive got the drill and wire wheel ready and got some plates from work today ill update on the weakend! so would you say thats bad or not?
Old Oct 27, 2010 | 05:21 PM
155lee's Avatar
155lee
cant see for all the smeg somebodys plastered on the floor.if water has got in it will sit between the sill and floor and just rust away.get it up in the air and look underneath.you may open a can of worms or you may catch it in the nick of time.have fun holding onto the drill with a wire wheel on it!
Old Oct 27, 2010 | 05:36 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
[quote=155lee;5155524]cant see for all the smeg somebodys plastered on the floor.if water has got in it will sit between the sill and floor and just rust away.get it up in the air and look underneath.you may open a can of worms or you may catch it in the nick of time.have fun holding onto the drill with the wire wheel on it
ok mate ill try lol hopefully ill catch it in time im going to be devo if its bad
Old Oct 27, 2010 | 05:39 PM
155lee's Avatar
155lee
it will just take longer if its bad.if the inner sill is gone then i would pull the kit off at the front as it hides the sill so if theres any foosty bits on the outer sill you wont see them.its funny,usually the pass side rusts 1st but my drivers side was the side needing welded,same as yours!
Old Oct 27, 2010 | 05:51 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
ive got my mates ramps here but you can pump them up so i should get a decent height ill have a decent look underneath and try and clean it up and find any rust i can its never ending with this cossie!
Old Oct 27, 2010 | 05:59 PM
Moose 130's Avatar
Moose 130
Old Oct 27, 2010 | 06:10 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Old Oct 27, 2010 | 06:20 PM
steves24V's's Avatar
steves24V's
I wish I had some pics of my mates discovery not a ford i know but his car is 6 years newer than yours, you would feel a lot better his has been off the road 2 years.
Old Oct 27, 2010 | 06:26 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
thats been well played with already by the looks of things...
Id start chopping and see what youve got!
Old Oct 27, 2010 | 06:54 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
hopefully itl turn out to be ok gutted i wudnt of even realised if i didnt go to hoover my car lucky really with the winter comming
Old Oct 27, 2010 | 09:50 PM
markc's Avatar
markc
need any more!?
Old Oct 27, 2010 | 09:53 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
lol i think that'll do mate, wish i could weld it myself
Old Oct 27, 2010 | 10:06 PM
chrisa3's Avatar
chrisa3
I had to weld two small plates on my footwells about 10cmx10cm, although that seems like its been welded before and not treated afterwards. Its pretty scary how thin and flimsy the metal is around that area. Once you have finished welding, get some red oxide paint and cover everything with it inside and out.
Ive peeled back all the tape on my inner sills and filled them all with Bilt Hamber anti corrosion treatment. I bought 2 canisters and filled everywhere with the stuff, chassis legs /rails sills etc.
It sat on axle stands and bled for a day or two until it set. Good stuff though. Give it a go once you have finished!!
http://www.bilthamber.com/dynaxs50.html
Old Oct 27, 2010 | 10:10 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
cheers mate im just hoping theres not anymore when i pull the carpets up ect
Old Oct 27, 2010 | 10:19 PM
phil_focus's Avatar
phil_focus
i think i'd be rippng out the interior to be honest to find every little bit. take it off the road, stick it in the garage and play rust hunter over the winter. next summer it can come out of hiding all spick and span and ready to go.
Old Oct 27, 2010 | 10:28 PM
chrisa3's Avatar
chrisa3
Fingers crossed for you matey. I know first hand how you feel. But you have to ask yourself the question, would you not rather know and be able to fix it??
Just got to make sure you chop all the rot out to good metal.
Old Oct 27, 2010 | 10:31 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
aye thats true mate the interior will be out on the weekend and if i cant sort it barrys going to get it done for me cheap so should be areet a havent got a garage tho soo its all gota happen in this fine british weather lol getting a classic additions cover tomorow so should protect over the winter the best i can
Old Oct 28, 2010 | 05:42 AM
scottyrs's Avatar
scottyrs
DURHAM RSOC
the jacking point underneath is all creased in aswell would that have anything to do with this? ive never had it jacked up but noticed yesterday? what causes that
Old Oct 28, 2010 | 06:49 AM
155lee's Avatar
155lee
if its been jacked up with atrolley jack behind where the proper jacking point is it will pull at the seams,crack underseal and damaged the floor.maybe this has caused some of the damage.
Old Oct 28, 2010 | 07:23 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
great the other side is crushed aswell but havent got the carpet up yet so hopefully ill be ok
Old Oct 31, 2010 | 05:44 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Default rusty floors :( UPDATE STRIPPED INTERIOR pics inside
well stripped it out today and lifted the carpets to see if i could see much more rust as i found my first bit last week and heres what i found
well i was surprised apart from the dodgy drivers footwell i didnt find any mayjor rust just abit of surface which ill try and clean up, is the rust along the side of the floor anything to worry about or can i just clean that up aswell? cheers
Old Oct 31, 2010 | 05:58 PM
ShiftyOldScoob's Avatar
ShiftyOldScoob
Mate I've seen a 100 times worse than that !.....Looks good considering it's been used as a daily for god knows how long !
I've got a really good wire wheel and a variable speed grinder you can borrow....Just buzz off any surface rust you find (be prepared though, it could turn into a hole )
then give it a good coat of primer + paint with rattle cans...then I'd lash on a load of wax oil just to be sure !
check your door seal mate, could possibly be leaking through there....honestly though, it looks alrite !...its been played with a bit before but nowt that isnt an easy fix !
Old Oct 31, 2010 | 06:02 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
cheers mate thats weird was going to ask if you had one lol, just need to get the worse bit sorted tho anyday now then i can take my time sorting the rest want to paint it again then try and clean and underseal the underside aswell just bought some axel stands ect the day and got loads of thinners from work lol should be fun in this weather
Old Oct 31, 2010 | 07:21 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
oh and when i was trying to undo the bolts for my seats 2 heads snapped off so the rest of the bolt is still in the floor whats the best thing to do just drill it out? cheers
Old Oct 31, 2010 | 07:34 PM
phil_focus's Avatar
phil_focus
is there much of the bolt protruding?? if so you can get stud extractors.
if not your gonna have to drill them out and clean the threads up with a tap.
one note though its very easy to drill the whole off centre which makes it a little more difficult.
Old Oct 31, 2010 | 07:35 PM
Fiddy's Avatar
Fiddy
in terms of old saffs mate, its not bad at all, ive seen a WHOLE lot worse than that. i was paranoid with my mondingo, they love to rust, but i got mine up on a ramp, and checked my floor pans, and there isnt a spot, or on the sills and chassis legs, its just the rust on the top side i need to sort lol. got a nice spot rite next to one of the bumper brackets, and a few bits around my rear window. ive got a feeling, this winter may be its last before it needs dealing with, but at least structurally, its sound.
Old Oct 31, 2010 | 07:40 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
afraid not mate its snapped clean off and its flush with the floor so think ill have to drill it!
Old Oct 31, 2010 | 07:41 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
i know what you mean mate ive never ever worried about rust on any of my cars untill my saffs now im just always paranoid and worrying about it lol glad to know mine isnt to bad ive never seen any more the first time ive ever done anything like this so didnt no weather it was good or bad ha
Old Oct 31, 2010 | 07:50 PM
Fiddy's Avatar
Fiddy
as sure as water is wet, and the sky is blue, unless its a low mileage, pampered, and lives on a bed of feathers saff, it will have rust somewhere mate.
the mk1 and mk2 mondeos are newer, but there just as bad. i know an ST24 that has just been scrapped, it was two years newer than mine, and done half the miles, and on the top side, there wasnt a spot of rust, arches, no where, it looked from the outside, like a concours car, but get underneath it, and the sills, floor pans, and chassis legs, were rotten as a pear, so it got scrapped. but obviously V6 mondys are ten a penny, you scrap it, and buy another one, but even a rotten saff, is worth saving, because there worth good money.
and like i said, as far as everyday usage saffs go, your looks pretty sturdy mate. wont take much to sort that.
