how much is my fully loaded l8 ecu worth?
Old Oct 21, 2010 | 12:29 PM
B13 JUS's Avatar
B13 JUS
Default how much is my fully loaded l8 ecu worth?
i have a fortune in this ecu and i been thinking of using a after market ecu.
just was woundering how much mine was worth?
its a l8 ecu with msd live map chip with anti lag, launch control, wasted spark.
al & lc is £450 alone.
the spec of the chip is close to standard comp, pistons where standard comp but have valve cut outs, ported head, bd14 inlet and standard exhaust cams
4x4 inlet with 10mm spacer, siemens 83lbs injectors, t4 turbo.
the 4x4 inlet with spacer could be sold with the ecu as i have now got a hart plenum.
Old Oct 21, 2010 | 12:58 PM
JamesH's Avatar
JamesH
I sold my L8 with wasted spark driver, no chip, for £300 a few weeks back, hope this helps mate!
Old Oct 21, 2010 | 01:14 PM
derekd's Avatar
derekd
around 550/600 i would say mate depends on how fast u want it sold realy
Old Oct 21, 2010 | 02:29 PM
B13 JUS's Avatar
B13 JUS
yeah cheers mate.
so i have al,lc and chip with my map ontop of that price
Old Oct 21, 2010 | 02:38 PM
JamesH's Avatar
JamesH
Yeah I'd say so, roughly £300 for just the ECU, plus what you would value the chip at
Old Oct 21, 2010 | 03:05 PM
R4N SS's Avatar
R4N SS
i would never spend that sort of money on an L8 - better off going aftermarket as all the functions you have added come as standard on most modern ECUs - for example a brand new Omex 600 ECU is 600
Old Oct 21, 2010 | 03:51 PM
B13 JUS's Avatar
B13 JUS
so i would be best of selling my ecu seperate to my chip so if someone had a l8 ecu already and wanted al and lc it would be a cheaper way to get it by buying my chip?
they would get al & lc plus a map for less than you can buy it new.
my map cost me over £500 plus al/lc is £450
so think i would get £350 for it?
Old Oct 21, 2010 | 04:09 PM
RS SHAUN's Avatar
RS SHAUN
Might be intrested in the complete inlet mate?
Cheers Shaun
Old Oct 21, 2010 | 04:32 PM
jamie's's Avatar
jamie's
hard 1 realy, if somebody has this exact spec and was gonna buy all this,
then its worth good money to them,
however 99% of people would go aftermarket ecu at this level,
defo think its best to sell seperate if poss,
think 350 might be a bit steep as its a live map to your engine and so only
good as an off the shelf chip(but less safe) to anybody else,
but yes it is still cheaper than buying al/lc so still cheap so hard to call
Old Oct 21, 2010 | 07:57 PM
B13 JUS's Avatar
B13 JUS
its not a hard spec to copy really t4, bd14 inlet cam, standard comp.
it would be better than a of the shelf chip if you had the above as i got a of the shelf chip from msd to drive the car down before this live map and it ran crap.
Old Oct 22, 2010 | 09:06 AM
R4N SS's Avatar
R4N SS
i think 350 is a fair price mate.
or you could try list it separately on ebay and see you do - (prob best option really)
Old Oct 22, 2010 | 12:58 PM
BRAMMER's Avatar
BRAMMER
It is a cheap was of getting every MSD goodie on your car, Justin you didn't state std board or pect
Old Oct 22, 2010 | 02:08 PM
PAUL S's Avatar
PAUL S
seen a few of these sell fully loaded with MSD add ons for about £550, a basic L8 with board can range from £200 to £250 normally.
I would try to sell it complete rather than mess about splitting it up, ebays your best bet as it will no doubt go abroad that way.
Old Oct 22, 2010 | 02:37 PM
B13 JUS's Avatar
B13 JUS
its a standard board
Old Oct 22, 2010 | 02:40 PM
B13 JUS's Avatar
B13 JUS
i have fully decided if i will sell it yet but would only split if the chip went first.
i want a after market ecu but i will be looking at well over 1k for a ecu and loom.
Old Oct 22, 2010 | 03:07 PM
BRAMMER's Avatar
BRAMMER
Do these car absolutely need aftermarket?
Old Oct 22, 2010 | 03:25 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
why are you changing to aftermarket ecu? Surely its fine as is, just have it remapped with your plenum on?
Old Oct 22, 2010 | 05:06 PM
B13 JUS's Avatar
B13 JUS
no they don't but i just fancy something i can get into myself so i can understand mapping abit more
B13 JUS's Avatar
B13 JUS
as above mate
Old Oct 22, 2010 | 05:34 PM
jamie's's Avatar
jamie's
i completely agree mate,
but the idea of a live map is so that its perfect for your exact engine
as you'll full well know that no 2 engines are exactly the same,
i'm just trying to show both sides of the argument for and against,
i'm actualy in the exact same position,
i have a l8 with msd a/l, l/c, closed loop, siemens etc its cost me a small country's national debt to get it where i want it,
i'm gonna put my engine in a mk2 escort over the winter and thinking of switching to aftermarket management cause my loom has seen better days,
so instead of buying a new loom i was thinking of just changing the lot as it'll need another remap anyhow as i'll be chamging my intercooler and ex manifold etc,
so i realy am interested in what this makes for similar reasons to yours
JK12
33
Apr 26, 2021 12:09 PM
jessie_rs
62
Aug 6, 2019 09:27 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
normink
Wheels and Tyres
Sep 15, 2015 11:25 PM
Adam Graham
Sep 6, 2015 06:04 AM
