Dry sump
Old Oct 13, 2010 | 12:25 AM
Blunt.RS's Avatar
Blunt.RS
Default Dry sump
Anyone run one & what you do with the alternator
Cheers S
Old Oct 13, 2010 | 03:39 AM
gus's Avatar
gus
alternator you could fabricate a bracket to come off the arb corner plate (not sure what a s2 set up is like, have only looked into s1 / rs16i)
they not needed really imo a baffled sump should be more then adequate. cant think of anyone having oil surge issues
will free up a little power tho and prevention IS better than cure
Old Oct 13, 2010 | 09:40 AM
Blunt.RS's Avatar
Blunt.RS
Cheers Gus
16i ill be useing never thought about mounting of the engine only thing i could think of is mounting it to the back
Old Oct 13, 2010 | 10:59 AM
gus's Avatar
gus
yeah you could do
i didnt look at that either as thats where my turbo is
Old Oct 13, 2010 | 11:33 AM
RAT8OY's Avatar
RAT8OY
Horrendous job. Only go dry sump if you have too.
I am and the alternator is being changed for a tiny Denso item with custom mounting brackets water pump mods and cutting the new sump about to get the oil pump where it will work best.
Old Oct 13, 2010 | 12:06 PM
nigel b's Avatar
nigel b
it would be a struggle to fit it
the alternator would need moving slightly and have to be smaller
there is alot of clearance issues but i bet its not impossible!
Old Oct 14, 2010 | 09:59 AM
Blunt.RS's Avatar
Blunt.RS
Cheers guys got a spare engine so could mock up on that 1
Have you got any pics mate
cutting the new sump about ? i thought a dry sump would be already to bolt on
Old Oct 14, 2010 | 10:06 AM
Luca's Avatar
Luca
Lukesville
Nope they dont seem to make a dry sump for a FWD application only RWD.
Out with the welder!
Old Oct 14, 2010 | 10:34 AM
Blunt.RS's Avatar
Blunt.RS
Alright if you can weld lol
am comeing down eastligh soon is it alright if i bring it down
Old Oct 14, 2010 | 02:46 PM
Blunt.RS's Avatar
Blunt.RS
and thier was me thinking all cvh's where fwd
itll be easyier to sell up but thats just sensible
wish id had a closer look when i was up scholes place i know he had on 1 on his engine
jessie_rs
62
Aug 6, 2019 09:27 PM
Iain Mac
Sep 30, 2015 09:39 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
youngben
Sep 27, 2015 09:37 PM
timsrs
22
Sep 24, 2015 08:14 PM
