spanner and socket help!
Old Oct 12, 2010 | 03:43 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Question spanner and socket help!
Hello,
So have i been looking for a spanner/socket conversion chart.
I have found sites as
http://www.baconsdozen.co.uk/tools/c...n%20charts.htm
http://www.csgnetwork.com/wrenchsizetable.html
But i just dont understand it, I know there is no real conversion but i want to get then as close to the mm as i can so then i can put them in order! What is 6/7 or 5/16 and sometimes without the / and a - instead, so 6-7.
Like i said i wanted a easy chart as i have worked out that 5/16 is 0.600 inch so its 15.24 mm. Thats alot of math on the spot when needed a socket!
As for the 6-7 i cant find on the chart anywhere! But i have a socket with that on and its kinda big (20mm ish)
Many Thanks Eigdoog!
Lets the rants begin
Old Oct 12, 2010 | 03:46 PM
wirralphil's Avatar
wirralphil
Sure you don't mean 7/8th, that size is around 22mm.
HTH
Old Oct 12, 2010 | 03:50 PM
bookwyse's Avatar
bookwyse
The easiest way is to set up an excel sheet and do it yourself.
The basic maths is easy.
Take the imperial size of 6/7 which means the socket is 6 sevenths of a inch. You dived 6 by seven which is: 0.857 and then multiply this by 25.4 (25.4mm makes one inch) which gives you 21.7mm
EASY
Old Oct 12, 2010 | 03:53 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Come to think of it, it may have been 7/8.
Thanks for the chart! I can read that one better than the others.
I could do my own sheet but thats time :'( and thats money :P I will use math if i get ones im stuck on, Thanks!
Thanks
*Prints off*
DanDMC
33
Oct 7, 2015 01:58 PM
Si B
Sep 12, 2015 06:49 AM
Aug 29, 2015 08:16 PM
rst-s1
Aug 23, 2015 07:56 AM
