S2 88spec clocks
Old Oct 9, 2010 | 03:29 PM
bencossie's Avatar
bencossie
Default S2 88spec clocks
Am i right in thinking that you can remove the clocks with out taking the whole of the dash out only the front panel. Also any easy trick to get the plugs dissconnected also how many plugs are there in the back
cheers
Old Oct 9, 2010 | 03:36 PM
ROB7656's Avatar
ROB7656
just remove the fascia around the clocks then its just 4 screws.
Old Oct 9, 2010 | 03:38 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
ok there is two plugs at the back plus speedo
easiest way is to put hand through where the fuel comp would be
un plug first connector
lift forward putting the left side of clocks back in (so they slot behind dash)
giving more room to un plug speedo and second connector
hope this helps
Old Oct 9, 2010 | 05:00 PM
bencossie's Avatar
bencossie
yer ill give that a go cheers i got the 4 screws done just the plugs i had trouble with
Old Oct 10, 2010 | 08:38 AM
bencossie's Avatar
bencossie
quick question peeps just got the clocks out wat the two types of bulbs in the dash
Mark_
14
Jan 16, 2016 05:27 PM
cossie brad
Sep 29, 2015 02:38 PM
Mr S1
20
Sep 27, 2015 04:06 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
