s2 wiring problem, any ideas??
Old Oct 9, 2010 | 01:00 PM
mikey_clough's Avatar
mikey_clough
Default s2 wiring problem, any ideas??
hi all, ive got s2 that i very recently changed to efi ofab management. Now the engine runs fine but when i activate the rear wiper, which operates the reverse lights as i wired it up wrong and putting in reverse activates the rear wiper, need to get round to sorting that! when i press it and turn the high beam lights on loads of lights come on the dash and the fuel pump cuts out?? ive disconected loads of stuff and cannot make it any better, im thinking maybe a wire is shorting out somewhere but was hoping someone else has experienced this problem?? any help would be great!! thanks
Old Oct 10, 2010 | 06:51 PM
dave_s2_rst's Avatar
dave_s2_rst
sounds interesting, im no wiring expert here, was the issue occuring at all before the management change? Sounds like you may have wired incorrectly, put a post up in the technical section too. check you wiring for efi is correct and start checking back on the existing loom.
As it is with these things its all about checking back.
Did you stay with the original car loom or did you change this as well?
big_Rad
Sep 15, 2017 09:36 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
