piper T2 or newman stage 3?
Old Oct 9, 2010 | 11:12 AM
andy130's Avatar
andy130
Default piper T2 or newman stage 3?
which is best between 240-260? soild lifters? which works best with T34/48 ext/L8?
spec of rest my engine
mahle pistons standard (CR)
PEC rods
payen head gasket
ported head
EFI manifold
t34/48 ext housing
L8
grs intercooler
Old Oct 9, 2010 | 11:15 AM
Nick.W's Avatar
Nick.W
Newman,only because im bias!
Old Oct 9, 2010 | 11:16 AM
andy130's Avatar
andy130
which one tho? the one that uses soild lifters?
Old Oct 9, 2010 | 11:21 AM
Nick.W's Avatar
Nick.W
Yes solid lifters and double valve spring although i was told to not use the double valve springs
Old Oct 9, 2010 | 11:24 AM
andy130's Avatar
andy130
cheers mate
Old Oct 9, 2010 | 11:31 AM
Russ Payne's Avatar
Russ Payne
newman all the way!!!!
Old Oct 9, 2010 | 04:28 PM
essexRSTSouthend's Avatar
essexRSTSouthend
Not to use the double valve springs?did they say why.seems strange.
Old Oct 9, 2010 | 04:29 PM
rsmark86's Avatar
rsmark86
its to reduce cam wear ...
Old Oct 9, 2010 | 06:41 PM
nigel b's Avatar
nigel b
alot of it is also low oil pressure on the head
Old Oct 9, 2010 | 07:23 PM
marky_g's Avatar
marky_g
Fleet Manager
what about cat cams?
Old Oct 10, 2010 | 12:39 PM
essexRSTSouthend
Still sounds weird.but ok lol
Old Oct 10, 2010 | 06:01 PM
craig rst kid's Avatar
craig rst kid
i looked earlier on thier web ite and couldn't find a cvh one i have gone kent cvh 35 with a vernier going to stick with hydraulic lifters as i am not planning mega power has anyone else had this kit
Old Oct 10, 2010 | 06:15 PM
Rob_DOHC's Avatar
Rob_DOHC
No need, standard springs i hear are fine for 6500rpm, any more spring pressure than necessary (for your rpm limit) and you just pointlessly increase frictional loads and wear.
Rob,
Old Oct 10, 2010 | 06:58 PM
rsmark86's Avatar
rsmark86
well im looking for 7000rpm limit on mine so would the standard springs still be ok
Old Oct 10, 2010 | 07:04 PM
Rob_DOHC's Avatar
Rob_DOHC
Im sure what ever spring are supplied with the newmans cam are man enough. Some one like Karlos will be able to tell you.
Rob,
Old Oct 10, 2010 | 07:08 PM
rsmark86's Avatar
rsmark86
ok mate well im gunna get a newman at the end of the month but aint got a clue how to adjust the solid lifters
Old Oct 10, 2010 | 07:10 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I run stock 20 year old springs as instructed by Karl Norris and my limiter was at 7200rpm, did many many runs at that without probs only dropped back to 6600rpm because my T3 runs out of puff long before that, also IIRC Tim runs them at 7800rpm so they will be fine Mark.
Anything heavier and your just wearing away your cam and lifters for no reason, CVH heads have a very heavy valve train and poor lubrication so it's not good at the best of times lol
Old Oct 10, 2010 | 07:11 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Do a search for one of my old threads about Newman cam fitting mate
All you need to know is in there...
Old Oct 10, 2010 | 07:13 PM
rsmark86's Avatar
rsmark86
wicked cheers karlos your the man lol.... so i need to buy cam/lifters and tool and ive got the slightly uprated valve springs they used with the power engineering cam which are like standard ones
Old Oct 10, 2010 | 07:14 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Newman sell it all as a kit Mark for Ł300 delivered.
Old Oct 10, 2010 | 07:15 PM
rsmark86's Avatar
rsmark86
wicked well im so close cant wait to here 7000rpm cvh at 2bar of boost with 4" scorpian tail pipe poping and banging lol
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
