urgent starting help needed!
Old Oct 7, 2010 | 03:53 PM
geordiegooner's Avatar
geordiegooner
Default urgent starting help needed!
right basicly i've a 56 plate focus tdci and the diesel light came on last night but only done 4 miles to get home,now the car was parked on a steep hill and when i came out this morning the car started fine done about 100 yards and stalled and now refuses to start.
i've put diesel in it tried to start it nothing i've had it towed around the street and still wont start.
i now have the engine system fault warning light on on the dash the engine still turns over but seems like theres a fuel cut out switch somewhere prehaps that is stopping diesel through to start it anyone any idea's as i need to get it started asap.
thanks for any help
andy
Old Oct 7, 2010 | 06:38 PM
geordiegooner
anybody help please?been pissing about for hours now starts for a second then cuts out straight away could it just be air?
Old Oct 7, 2010 | 06:55 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
What's the fuel filter like? If it's an upright cannister like on the Mondeo TDCi you need to fill it with diesel if it's run dry, otherwise you're just sucking up air!
Old Oct 7, 2010 | 07:12 PM
geordiegooner
yes i think it is a upright cannister too there's a valve on the top as well that i've been sucking the air out till the filter seems full of fuel starts for a second then just cuts out.
Old Oct 7, 2010 | 07:46 PM
LHD220Turbo's Avatar
LHD220Turbo
these are a fucker to start if you get ANY air in the system. try a new filter soaked in diesel and fill the housing with diesel too.
Old Oct 7, 2010 | 08:02 PM
geordiegooner
think im going to fill the filter through the valve on the top of the cannister with diesel tomorrow see if i get any joy that way
Old Oct 7, 2010 | 08:05 PM
wayne dowling's Avatar
wayne dowling
i serviced one at work yesterday and i ended up cracking the injector pipes off and blowing compressed air in the tank to push the fuel throu
thanks wayne
Old Oct 7, 2010 | 08:19 PM
geordiegooner
thanks wayne
i'm sure its only air related fault the only thing i got is a easy bleed brake kit just got to think how i can use that to force the air out.
Old Oct 7, 2010 | 08:40 PM
saph4be's Avatar
saph4be
do not flatten the battery i did on one off these and the car yhrew a fit and had to go to ford to reprogramme the immobiliser or something
Old Oct 7, 2010 | 09:22 PM
cossytel's Avatar
cossytel
If its just an airlock it should tow off fairly quickly, same problem when changing fuel filter. I always fill the filter bowl up first and release the fuel cap, works for me.
Old Oct 7, 2010 | 09:47 PM
nickywarwick's Avatar
nickywarwick
tdci's are a twat if youve got air in an cracking injectors off can make it worse as it picks up a fuel pressure drop. loosen the screw on the filter head and fill it brim full, give it a few turns an it will start, failing that give it abit spray of f*cking start you c*nt in a can & it will pull the fuel through.
cheers nic
Old Oct 7, 2010 | 10:29 PM
vaughant's Avatar
vaughant
Tow the fucker,should go eventually,my passat tdi totally refused to start,booster pack,big battery etc.towed and all was well!!!
Old Oct 8, 2010 | 09:34 AM
geordiegooner
towed it for a while yesterday,was as though the engine had started but no revs when pressing accelerator.
Old Oct 8, 2010 | 09:36 AM
geordiegooner
cheers nic
where would you spray easy start on a diesel engine?
Old Oct 8, 2010 | 09:42 AM
vaughant's Avatar
vaughant
Hmm,that's me out of ideas a bit then as that's usually enough.do you know anyone locally with a fault code reader just to check?can't see how it would have run out of diesel after 4 miles with the light on,there's usually about 2 gallons in the reserve tank?
Old Oct 8, 2010 | 09:59 AM
F1N9ERS's Avatar
F1N9ERS
Hey Buddy where abouts are you? i work for a garage in mitcham south london we can put it on our lap top ( NO i wont charge you) DONT worry ill get it started.. But like the guys have said it most likely is the filter fill it right to the brimmmmmm dont crak off the injectors or anything spray A LITTLE easy start not to much or it will sound like the engine is locking up deff air in the system
Old Oct 8, 2010 | 10:09 AM
geordiegooner
cheers for the offer mate but i'm in newcastle upon tyne so a bit far where do you spray the easy start into ?
Old Oct 8, 2010 | 10:12 AM
geordiegooner
think it was just because it was on a very steep hill with the front of the car pointing upwards.dont know anyone near by with a fault reader either.
Old Oct 8, 2010 | 10:23 AM
vaughant's Avatar
vaughant
Bastard!if you get REALLY stuck I could post you my fault reader and then you could send it back to me but you won't really get that until Monday now
Old Oct 8, 2010 | 10:50 AM
geordiegooner
cheers mate thats also very kind just went out to start on it again put my power pack on it and the b@stard started straight away no problem
Old Oct 8, 2010 | 12:42 PM
nickywarwick
spray it directly into the intake mate, easiest way is through the airbox, spray it after the air filter so if you have to take the filter out then spray it down the pipe work, failing that, take the intake pipe off the inlet manifold and spray it directly into the manifold
cheers nic
*just read ure post ^^ doesnt matter now lol
Old Oct 8, 2010 | 07:25 PM
vaughant's Avatar
vaughant
Great stuff!!!was the battery a bit shit then?we had a tdci Mondeo,been hit but running fine, came in and it was a minter,50k,full history etc.it had a massive battery on it,looked like a caravan battery,so I thought fuck that,that's going on my Cherokee!!shoved the Cherokee battery on the Mondeo and it barely turned over,booster packed it and it just about went!!what with the current cold weather it could just be highlighting the fact the battery is slowly on its way out?
JoeyBoyden
Jan 4, 2024 02:36 PM
Fordmad!
Sep 26, 2015 05:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
col93saphcos
Aug 7, 2015 03:21 PM
