T34 Turbo - .63 cool / .63 hot
Anyone used this config for the T34? If so how laggy is it? I have this setup for my Mk1 Cortina Cossie 4x4 but not sure if she will be too laggy.
laggy compared to what?
t34.63 will make 400hp on the right spec - its an awesome road car set up.
t34.63, ab07 inlet, siemens 55lbs injectors, and a decent chip such as MSD, 2.2bar of boost would see 400hp. be careful of the standard 4x4 gearbox thou, anything beyond 400/400 is a lottery
On a STD engine to push 400 out of a t34 is asking a little too much and they don't like holding 2.2 bar at high revs, I spike of 2.2 is good but they are Time bombs at that boost iirc mike rain bird done a few t34's pushing over 400 bhp
The .48 is better for a road car IMHO though loose 20 or so hp for more response
What about the bottom end? Its been lightened and balanced but standard pistons and con rod bolts.
I'm after reliability as the car is more of a street sleeper than track / 1/4 mile dragster.
Yip got a grp A on her.
Set up is;
0.75 overbore (lighten & balanced cranks, rods, flyweel)
T34 .63 / .63
3 bar MAP
Greens
Pro Alloy 50mm RS500 I/cooler
MSD chip to match above.
What do you think she will put out? Was hoping 350bhp.
Set up is;
T34 .63 / .63
3 bar MAP
Greens
Lol! Think this is the conversion for me or very similar
Matt Baxter
Sep 16, 2015 08:30 PM
kosienutter
31
Aug 22, 2015 09:55 AM
but a uprated head gasket is advisable something like a 0611/grp a gasket
