Saff with 8" and ET32
Old Sep 27, 2010 | 08:55 PM
RS-Stian's Avatar
RS-Stian
www.fordclubnorway.no
Default Saff with 8" and ET32
Does anyone runs 8" wide wheels with ET32 at the front on their saff 2wd? If yes, does it fit inside the arch without any mods?
The reason why i'm asking because i just received my wheels that are ET32,5 at the front and i'm not sure whether they will fit inside once the car is lowered to the ground.
Old Sep 27, 2010 | 09:07 PM
Nash's Avatar
Nash
Cake lover!
Yeah they will fit, Grp A offset if ET33 and they fit fine. The arches will need to be rolled though.
Old Sep 28, 2010 | 05:15 PM
RS-Stian's Avatar
RS-Stian
Cheers mate. Just what i was thinking, with a offset lower than 33 the arches needs to be rolled. Definitely not going to do that on mine so i will have to send the wheels in return
Old Sep 28, 2010 | 05:53 PM
crumpet's Avatar
crumpet
cant you use stretched tyres mate to clear?
Old Sep 28, 2010 | 06:13 PM
Ridgey's Avatar
Ridgey
Just roll the arches, Saffs look so much better on a et32-35 with 8" rims
Plus it very much depends on the height the car is running at.
Old Sep 28, 2010 | 07:03 PM
KSA-Cossie's Avatar
KSA-Cossie
Off topic,but can you fit 225/35/18's to saphs ? Mine has 8x18 old style 6 spoke MO's ET35 with gaz gold coilovers.
Old Sep 28, 2010 | 08:46 PM
RS-Stian's Avatar
RS-Stian
Could do as i have plans running on 215/40, but my main problem is that the wheels is catching the brake caliper
Old Sep 28, 2010 | 08:49 PM
RS-Stian's Avatar
RS-Stian
I know mate but i originally ordered et35 and got et32,5. Still going for 8" but hopefully et35, better to use a 1 or 2mm spacer to adapt them perfectly without the need of rolling arches.
Old Sep 28, 2010 | 10:25 PM
crumpet's Avatar
crumpet
ahh i get your point now, spacers can be dangerous too, if it doesnt cost anything to get et35 instead of 32.5 i would, love those wheels
cossie330
Oct 7, 2015 08:22 PM
cossie330
Sep 27, 2015 04:13 PM
ajamesc
Sep 27, 2015 02:25 PM
cameron2
Sep 25, 2015 04:44 PM
mrmann
Aug 20, 2015 11:24 PM
