quick question,s2 stereo,interior light and clock stopped workin?!
Old Sep 27, 2010 | 12:52 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
Default quick question,s2 stereo,interior light and clock stopped workin?!
in my s2,for some reason the stereo,interior clock and interior light have stopped working,all fuses look fine,so now im abit stimped,any ideas chaps. which fuse is it also,cheers
Old Sep 27, 2010 | 12:54 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
cant remember what fuse it is mate and cant check car cos at work lol but absolutely positive all those three things are on the same circuit so will almost deffo be the fuse, sure its a 10amp one.
Happened to me a couple of times.
Old Sep 27, 2010 | 01:01 PM
martinmilne's Avatar
martinmilne
deffo fuse same happened to mine inless the wiring has shorted
Old Sep 27, 2010 | 01:35 PM
rickbartlett
G911 TTA
could be wiring, im sure its one of the fuses in the rite rear corner of fuse box.just dont fancy rippin dash out to find problem
Old Sep 27, 2010 | 04:11 PM
Fuses listed in ford handbook and haynes manual.
Old Sep 27, 2010 | 04:50 PM
vaughant's Avatar
vaughant
Deffo fuse,they're all powered with a permanent live,again I cant remember what one as it was years ago.the only other possibility is a broken wire off the battery,although that's unlikely as you'd find other faults I'd imagine.
Old Sep 27, 2010 | 04:52 PM
vaughant's Avatar
vaughant
Double check the fag lighter as well as that's also perm live and iirc on the same fuse,I think that's the one your looking for,with a burning fag on it!!!
Old Sep 27, 2010 | 05:21 PM
rickbartlett
G911 TTA
all fuses look fine and the 2 fuses that are the ones it could be are both fine,have even changed them for 2 new ones just in case they werent visibly blown
Old Sep 27, 2010 | 05:45 PM
vaughant's Avatar
vaughant
Ahh bastard,you got power going to the fuse?And out of the fuse?otherwise its wiring issues I'm afraid.it shouldn't be too hard to find though,pull the stereo out and most of that loom comes through there.the clock unfortunately is more fiddly,it runs down the a pillar,bit of a stripdown job then.
Old Sep 27, 2010 | 05:52 PM
martysmartie's Avatar
martysmartie
Check you have +12V at one side of the fuse if not theres no point in going any further, make sure the terminals are clean and shiny if still no joy the wire has probably got a bad/broken connection on the underneath.
Martin
Old Sep 27, 2010 | 06:18 PM
rickbartlett
G911 TTA
will get a volt meter on the fusebox tomorow.bloody fords
Old Sep 27, 2010 | 09:59 PM
rst cabbie's Avatar
rst cabbie
gingeRS cabriolet
looks like another job for me then mate give me a text tomorrow mate
Old Sep 28, 2010 | 06:05 PM
rickbartlett
G911 TTA
all fixed,was a broken wire
Old Sep 28, 2010 | 06:13 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
Should of kept your scooby lol
Anutternutter
24
Aug 31, 2015 01:24 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
Ben26
Aug 11, 2015 04:19 PM
sridgett
15
Aug 3, 2015 07:26 PM
Old ford
Jul 31, 2015 06:50 AM
