cosworth rear suspension on a mk2 escort
Old Sep 26, 2010 | 09:05 PM
allyn78's Avatar
allyn78
Default cosworth rear suspension on a mk2 escort
can any body helpme out im starting a new project of a cossy powered mk2 escort. can any tell me how easy it would be tofit sierra rear suspenion to the mk2. thanks
Old Sep 26, 2010 | 09:14 PM
irishescorts's Avatar
irishescorts
You would need a lot of fabrication thats for sure, not an easy job
Old Sep 27, 2010 | 11:12 AM
You need to change the word easy to mental.
It would be mental to use sierra beam etc, all the fabrication needed you'd stil end up with a inferior product, sierra rear beam/suspension is nothing to shout about, it's fairly shit tbh,
Old Sep 27, 2010 | 11:27 AM
Fezman1's Avatar
Fezman1
Simple. DONT DO IT. Stick with the live rear axle or you'd be ruining the good old escort in my opinion. Cossie engine- yes. T5 box- yes. Rear suspension set up- no.
Well, maybe a 6degree rear beam and adjustable arms would be ok.
But alot of fabrication work involved to end up with an escort that would probably be heavier and not handle as well
Old Sep 27, 2010 | 12:19 PM
rubinsbin's Avatar
rubinsbin
atlas axle!!(capri inc slipper)-works axle!!
Old Sep 27, 2010 | 01:43 PM
JonnyBravo's Avatar
JonnyBravo
If you want to be different then fit a Nissan S13 subframe setup. I've just decided to use this setup over a Atlas on a mates Volvo to keep the costs down. GTS-T auto Skylines use 4.1 cwp's so use the diff from one of those. Everything is available for those setups, mainly from Driftworks etc.
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
