How much BHP?
Old Sep 26, 2010 | 01:24 PM
cossie04's Avatar
cossie04
Default How much BHP?
Right, to cut a long story short, i`ve bought my old 2wd cossie back and now it has a new engine. I don`t have a rolling road graph for it yet but this will be done in the next few weeks. My question, could someone please tell me roughly how much power it should have? The spec is as follows:
Low compression Accralite forged pistons
H section rods
ARP rod bolts
Lightened & Balanced Crank
High pressure oil pump
Cometic Multi layer Head gasket
ARP Nut and Stud kit
T34 Turbo
.63 Housing
Pace RS500 Intercooler
Airtec Rad
Black Siemens Injectors
044 Fuel pump
Motorsport Developments 380+BHP Chip
Grp A Coil
At the moment, it boosts at 7 psi which i`m told can be increased once i`ve fitted the fuel pump relay kit which will supply 12.8v.
Cheers, Ed.
Old Sep 26, 2010 | 03:25 PM
Danny @ Enhanced Performance's Avatar
Depends on boost but id get it set up on a rr mate and get the boost set safely...
Around the 2 bar of boost should give 380 ish hp and the same torque..
cheers danny
Old Sep 26, 2010 | 06:36 PM
Very odd spec especially for 7 psi, but well under 300 bhp I'd say I run on one map 17/18 psi on a T3/34 for 300bhp.
As Danny says first place it needs going is to a decent RR, to exploit the full potential of the engine/chip.
Old Sep 27, 2010 | 10:44 AM
cossie04's Avatar
cossie04
Mmm, that is odd as it totally wiped the floor with my mates scooby which was RR two weeks ago at 270bhp. Will get a rr done next week and report back.
Old Sep 27, 2010 | 10:57 AM
You've got a major advantage with 2wd over scoob 4wd, more advantage the faster you go.
Old Sep 27, 2010 | 11:48 AM
chaffe's Avatar
chaffe
Turbocharging Technician
a 2 litre 16v low compression running 7 psi of boost, is that not five less than a standard cosworth? 30% less boost, so less than 200bhp would be my guess?
Old Sep 27, 2010 | 02:24 PM
It has a larger turbo than std, higher flowing injectors than std, and a different chip to std.
Old Sep 27, 2010 | 09:48 PM
Plus its around std boost as most run around 8 psi
At 7 psi id say its approx 250-260hp..
cheers danny
Old Sep 28, 2010 | 06:15 AM
chaffe's Avatar
chaffe
Yeah it was a thought after i posted about the turbo size, so fair shout mate, i always thought they ran more boost standard, so yeah ill go with that 240-250 bhp. bigger injectors dont mean it will be quicker though lol.
Old Sep 28, 2010 | 10:28 PM
crumpet's Avatar
crumpet
i remember a mate telling me on mfi cvh's you could turn the nozzles in the injectors 180 degrees to make them richer and it would make 20+bhp lol
Old Sep 28, 2010 | 10:30 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
that must be shite on half a bar, thats still classed as lag in my book
Old Sep 28, 2010 | 10:37 PM
Joshy's Avatar
Joshy
Dreamer
not to turn this into a PF trademark debate but if your making boost then its not lag sorry....
Old Sep 29, 2010 | 03:35 AM
BRAMMER's Avatar
BRAMMER
I wouldnt even be driving it hard without a setup
Old Sep 29, 2010 | 06:08 AM
BLACKCOS's Avatar
BLACKCOS
get it set up first so you dont damage the engine
Old Sep 29, 2010 | 06:50 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Must be shit slow and painfully boring. Fuck all lb/ft from 7 psi
Old Sep 29, 2010 | 07:14 AM
rsmark86's Avatar
rsmark86
take it to msd or nms for a live map mate and should be a strong 380bhp
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Sorry Rich your wrong this car must be fast it wiped the floor with his mates Scooby & it has a 380bhp Chip. Still i suppose Cossies have as much bhp as you tell your mates.
Old Sep 29, 2010 | 07:23 AM
chaffe's Avatar
chaffe
Now now boys, at least the op has bought a ford and not a rice burner
Old Sep 29, 2010 | 07:55 AM
Karl 3dr's Avatar
Karl 3dr
A bit unfair really, I can't see anywhere where the op has "boasted"about power, in fact he was asking for a rough idea of what it should be.
Old Sep 29, 2010 | 08:49 AM
Joshy's Avatar
Joshy
Dreamer
^^^ +1
Old Sep 29, 2010 | 09:21 AM
Chip's Avatar
Chip
Agreed, he wasnt making any claims so no need to make out like he was doing so.
Old Sep 29, 2010 | 11:11 AM
LHD220Turbo's Avatar
LHD220Turbo
Old Sep 29, 2010 | 12:46 PM
martysmartie's Avatar
martysmartie
Standard boost is 0.7 BAR/0.8 BAR what you are running has been done for good reason most likely due to the new engine is my guess.
The fuel pump rewiring is done as the standard wiring can degrade due to it's age, building resistance and so you don't get the needed power at the pump. You want to actually be seeing alternator voltage at the pump WHEN under load, the fan OE wiring is also hopeless, even when new and needs checking/rewiring.
Even so you have a bigger turbo and other parts so even as it is at the moment I should think it's more than standard power around 2 BAR of boost should see the 380 mark, Impreza's are nothing special, so I don't see why everyone's piping up.
Even as standard there fast, it's just people compare to theirs which are tuned, so to them they would be slow.
Martin
Old Sep 29, 2010 | 01:22 PM
chaffe's Avatar
chaffe
.8 bar IS 12psi? .8x15=12psi .7x15=10.5psi
Old Sep 29, 2010 | 04:59 PM
martysmartie
Yes around the 0.7 BAR for 2WD I think 4x4 was listed as 0.8BAR.
Martin
Old Sep 29, 2010 | 05:28 PM
crumpet's Avatar
crumpet
been researching and i believe all yb's were 8-9 psi.
for running a fresh bottom end in though, id only run standard boost, obviously not too much to kill it, but enough to run it in, i know of people who have run their cars in like pussys and not even came on boost for 1,000 miles,been too careful, then ran alot of boost and manage to nacker it up in a matter of days... my chris astley built c20let was the same
Old Sep 29, 2010 | 05:39 PM
Chip's Avatar
Chip
He is at 7psi, which is just under 0.5 BAR
Old Sep 29, 2010 | 05:40 PM
crumpet's Avatar
crumpet
needs to get to mark shead or msd thens
Old Sep 29, 2010 | 06:12 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
BHP means next to nothing imo. Dyno-lotto!
Old Sep 29, 2010 | 06:25 PM
martysmartie
They would run around 0.8 BAR, at 0.9 BAR (13.5 PSI) fuel injection is cut off completely, this is a fact as from the handbook.
Martin
Old Sep 29, 2010 | 08:44 PM
chaffe's Avatar
chaffe
so standard cosworth boost should be 12 psi? so if he is running much less boost albeit with a bigger turbo, i would suggest the car is producing sub-standard power, ok the bigger turbos exhaust maybe slightly slacker, but the inlet boost is far less than std, and at this boost level i think the exhaust size has little effect on engine performance. But as said power means nothing, as long as your happy with what you have.
Old Sep 29, 2010 | 09:12 PM
CossieRich's Avatar
CossieRich
Who's the pussy hiding behind the tag. Man up you cissy
Old Sep 30, 2010 | 05:09 PM
cossie04's Avatar
cossie04
Well i can`t exactly say i`m surprised at some of the idiotic comments on here, but still, this is Passionford after all. I was purely asking roughly what sort of power i was looking at, not once did I claim i had i had more power than i actually have. Yes, i know it is a low amount of boost but i was told it was turned down to this figure until the fuel pump was sorted. Still, thanks to the few helpful comments, I now know roughly what to expect when i do go to get it setup.
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Marv888
Sep 26, 2015 03:44 PM
