Ford KA 1.3 8V Duratec P0030 Fault Code
Old Sep 25, 2010 | 03:43 PM
Halley70's Avatar
Halley70
Unhappy Ford KA 1.3 8V Duratec P0030 Fault Code
Hi every one,
I am new to the Ford Forum and need some advice and help with my wife's KA.
I have the engine management light on so I had the ECU scanned and it came up with the following code:
P0030 HO2S Bank 1 Sensor 1 Heater Circuit
I had it cleared and the light re-set but it has come back on again, with the same fault code.
Is this a fault with the Oxygen Sensor and if so is it the one on top of the manifold or the one further down the pipe !!!
Any help would be great.
Many thanks
Halley70
Old Sep 25, 2010 | 06:16 PM
16imarty's Avatar
16imarty
top one just check with multi meter on ythe white wires see if they have coninoty
Old Sep 26, 2010 | 07:57 AM
oldford's Avatar
oldford
Sensor 1 is always the first sensor in the exhaust, so in your case on the manifold.
Sensor 2 is the one after the cat.
Bank 1 is only applicable if you have more than 1 front O2 sensor.
Old Sep 26, 2010 | 04:40 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Have ya got any way to do a live data stream,
Old Sep 27, 2010 | 02:30 PM
Halley70's Avatar
Halley70
Hi,
Many thanks eveyone for your advice, I do not have the means to carry out a data stream, bit confused why it has shown up as bank 1 as I only have one sensor so do I change this one !! if yes any ideas where I can get one !!
Many thanks to everyone and I look forward to some more of the advice.
Many thanks
Halley70
Old Sep 27, 2010 | 02:33 PM
Halley70's Avatar
Halley70
Hi Every one,
Many thanks for your time and effort, so just to re-cap I just need to change the sensor on top of the manifold and then this should cure the fault !!
Any idea where I can get one with out being ripped off!!!
Many thanks
Old Sep 28, 2010 | 07:16 PM
forevaford's Avatar
forevaford
helo mate, p0030 means you have high resistance in the heater circuit of the 02 sensor. yes its usually the sensor but it might be the circuit its self. first check the resistance of the heater, 2 white wires i think. if this is open circuit then yes replace.
Old Oct 3, 2010 | 11:54 PM
Halley70's Avatar
Halley70
Hi,
Changed the sensor pre-cat and reset light, next day light came back on with fault code:
p0131 o2 sensor circuit low volts bank 1 sensor 1.
Any idea what I need to do next.
Many thanks
Old Oct 4, 2010 | 06:36 AM
oldford's Avatar
oldford
Original sensor? Check for exhaust leaks which cause the signal to be low.
Old Jan 25, 2011 | 08:09 AM
rysmee's Avatar
rysmee
hi there,
i think you'll find the pervious code p0030 is covered by a ford TSB, which involved updating the PCM software in conjunction with changing the hego (lambda). We often find people who have changed them but the light comes back on, so im afraid the only way is to go to a ford dealer who can do the update for you
not what you want to hear i know. you shouldn't need to change the hego again though.
Old Jan 26, 2011 | 05:08 AM
B19 JUB's Avatar
B19 JUB
Originally Posted by rysmee
hi there,
yeah true.the update changes sensitivity parameters in the ecu i believe and should always been done with a hego replacement on the ka ref the tsb
Old May 16, 2011 | 07:24 AM
Blink182_joel's Avatar
Blink182_joel
Exclamation P0030 tsb
Hi mate regarding the p0030 tsb, could you tell me where to get the info on this tsb?
borboyous
Aug 22, 2015 11:17 AM
nick8saff
Aug 16, 2015 05:35 PM
taylora1409
Aug 12, 2015 12:06 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
