Clifford problems
Old Sep 25, 2010 | 02:17 PM
cossie04's Avatar
cossie04
Default Clifford problems
I`m currently having a few problems with my clifford alarm. My first problem is when you arm / disarm, i only get the drivers side indicators flash, but indicators work fine from the stalk?. The second problem i`m having, trying to change the options within the alarm. It accepts the code when i enter it, but when i try to change the options, nothing happens? I have the manual which shows how to do it but no luck.
Could the two be linked?
Any help at all muchly appreciated
Old Sep 25, 2010 | 07:17 PM
I'm not 100% sure on the cliffys, but there may well be a fuse on each indicator line from the alarm unit, but these wires are what you need to check anyway to start with.
Old Sep 26, 2010 | 01:45 AM
cossie04's Avatar
cossie04
I`ve found 2 white wires from the clifford loom that join onto the indicator wires from the back of the stalk, but only one white wire has power??? Will check further up the loom for fuses in the morning
Cheers m8
Old Sep 26, 2010 | 08:40 AM
groomers's Avatar
groomers
Yeah they have two fuses good luck finding them haven't found mine yet, there properly hidden if it's been fitted properly!
Old Sep 26, 2010 | 10:32 AM
If a output on one indicator output from the alarm has gone duff inside the module there is a easy cheap way to get both flashing again using a few rectifier diodes, did this on me old COP IN A BOX alarm.
Old Sep 26, 2010 | 10:43 AM
STeve's Avatar
Super Moderator
do you not have the clifford lifetime warranty ~?
Old Sep 26, 2010 | 01:05 PM
cossie04's Avatar
cossie04
Not sure, I had the alarm fitted brand new about 4-5 years ago. I have the user guide for the alarm but no certificate? Will have to look that up...
Old Sep 26, 2010 | 08:01 PM
Cliffys normally do, where they and toad sting you is they don't pay "incidental costs" ie the cost of removing and fitting if needed due to a faulty unit, necessary to keep the cat 1 cert ok.
Steve Escos
Alloy wheels and ICE for sale
14
May 8, 2019 02:45 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
