cossie rocker gasket
Old Sep 17, 2010 | 07:24 PM
guth's Avatar
guth
Default cossie rocker gasket
hi all just about to fit a new rocker cover gasket to my big turbo cossie should i use some sealer with it or just the gasket its self.ive had oil leeks from here before and its getting on my tits now any tips would be good thanks
Old Sep 17, 2010 | 08:46 PM
4x4 S2 Cossie's Avatar
4x4 S2 Cossie
I use Hylomar Blue sealant and the gaskets with metal middles as they don't 'push' out when torquing down the cam cover bolts.
Cheers, Chris
Old Sep 17, 2010 | 08:49 PM
botters's Avatar
botters
competant bodger
just use sealent around the part where the rubber half moon seals go, it isnt neccesary to use it on the whole gasket.
i use hylomar blue as well
Old Sep 17, 2010 | 10:55 PM
guth's Avatar
guth
thanks for that ill give it a bash tomorrow and see how it goes
thanks scott
Old Sep 18, 2010 | 02:27 PM
What gasket you using ?, try a cometic one, and as said a little sealant around the ends of the cap seals, the ones with the metal spacers are for people that overtighten a alloy cover expecting it not to distort.
Old Sep 19, 2010 | 07:45 PM
guth's Avatar
guth
not sure tabetha i got it at ford fair from matt lewis racing. fitted it last night so far so good. is it possible for the rocker cover to distort?
thanks for your help
Old Sep 20, 2010 | 09:22 AM
4x4 S2 Cossie
Over tightening certainly won't help!
I disagree Tabetha (although i do agree that people over tighten in the hope that it will seal better). I use the metals as they have better torque retention and have not had any leaks from any i have fitted to date. Previously i have fecked around with other gaskets and always seemed to end up leaking. Personal preference i suppose.
Hope it's sorted now Guth.
Cheers, Chris
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
DAZZER
Sep 30, 2015 08:43 PM
deathrider666
Sep 28, 2015 06:12 PM
