fuel pump rewire wire size
Old Sep 16, 2010 | 04:39 PM
buttyrs's Avatar
buttyrs
Default fuel pump rewire wire size
gonna be re doing my fuel pump in the next couple of weeks whats the best size to use
chhers chris
Old Sep 17, 2010 | 08:28 PM
boost mad's Avatar
boost mad
Are you making a stand alone loom or just replacing the wire for the standard ?
3mm thin wall will cope with 33amp.
4mm thin wall will cope with 39amp
Old Sep 18, 2010 | 01:45 PM
www.vehiclewiringproducts.co.uk
Old Sep 18, 2010 | 09:23 PM
dazzle740's Avatar
dazzle740
The best way would be to run a fresh cable from the battery to the pump via a relay in the boot which you could use the old pump loom to switch on and off, but be sure to use the same size cable for the negative as you do for the positive.
Old Sep 19, 2010 | 10:46 AM
Best way involves also a new earth direct from the battery, a LOT more resistance builds up due to age/corrosion on the negative side.
Old Sep 21, 2010 | 06:01 PM
buttyrs's Avatar
buttyrs
just replacing the standard pump wires, so the 3mm thinwall will be fine for the positive and negative then cheers for the info
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
