motor swap
Old Sep 14, 2010 | 08:45 PM
onewheel's Avatar
onewheel
Default motor swap
hi dose any one know of any probs changing a tddi engine for a 2.2 st tdci i have a 01 tddi with a tied motor and a friend has a panel/chassis damaged car 06 st tdic, im thinking of transplanting it to mine.
so i have all elecs engine ect to do the job cheers
Old Sep 14, 2010 | 09:01 PM
phil_focus's Avatar
phil_focus
so long as yu have a complete donor car you should be able to make it work. you will have to swap EVERYTHING over though. whole fuel system including pump. wiring loom. dont know about mounts, that might be hard!
dont know about running the dash.
is yours a mk3 being 01? if so it should all swap straight over i would have thought
Old Sep 14, 2010 | 09:20 PM
onewheel's Avatar
onewheel
great, thanks, have whole car as the shell to bad to sort just need to find out about dash wiring if need to change if any one knows be great for info
Old Sep 14, 2010 | 09:21 PM
onewheel's Avatar
onewheel
ps yes it is a mk3
Old Sep 14, 2010 | 11:07 PM
phil_focus's Avatar
phil_focus
you should be able to swap it all over including ecu (might have to include locks and keys though for the imobiliser and alarm system), mounts, wiring loom, etc and might just be easiest to swap clocks over.
i wouldnt have thought it to be a quick job as your bound to hit problems but i'm sure the main bulk of the conversion will be straight forward and at least having the donor vehicle if you find say the sub frames are different at least you can swap them.
bobsworth
77
Mar 24, 2016 09:30 PM
cossie362
Oct 11, 2015 03:53 PM
marky_g
Sep 12, 2015 04:26 PM
grishenko45
Sep 9, 2015 12:58 PM
dojj
Sep 8, 2015 08:31 AM
