Converting 4wd to Rwd
Old Sep 13, 2010 | 05:22 PM
Cosworfh's Avatar
Cosworfh
Default Converting 4wd to Rwd
Hi all i'm just wanting to know what is involved in converting a 4x4 Saph to a rwd other than the obvious gearbox change. I know the 200 blocks are more sought after but every converted car i have seen where the 200 block has been retained seems to have the rwd head. Is it possible to use the 4x4 head also as from what ive been told its a better design.
I also remember a few years ago a mate of mine had a 3 door which he wanted to 4x4 as he had a written off saph. He never did it as according to him the wiring was all totally different so he ended up selling the 4x4 engine & gearbox
Old Sep 13, 2010 | 05:34 PM
rscos2004's Avatar
rscos2004
The heads are more or less the same you can use the 4x4 head the wiring is the same im using 4x4 inlet and ex manifold on my 2wd sapp as 4x4 inlet is bigger.
Old Sep 13, 2010 | 06:22 PM
Cosworfh's Avatar
Cosworfh
Does the 4x4 head have more water jackets for cooling?
Old Sep 13, 2010 | 06:59 PM
The heads do have different shape exit entry holes for the water passages, 4wd heads have a better water flow as well anyway due to the impellor surface area being that bit larger, the later the head the better, but 2wd heads can still be an excellent choice, depending on what you want, they don't need changing for the sake of it.
Old Sep 13, 2010 | 07:08 PM
FlashRS's Avatar
FlashRS
If you are converting it to 2wd, you keep all your standard wiring, its only the sump that needs changing! The 4x4 engine loom runs a "knock" sensor and lamda sensor, which is better, I think!
Oh yes and the engine mounts !!
Old Sep 13, 2010 | 08:06 PM
Turbosimpsons's Avatar
Turbosimpsons
you don't need to change the sump. just remove the front diff and the cross shaft. just converting mine at the mo. u'll need a 2wd starter motor and intermedate plate.
turbotrev
39
Apr 17, 2016 09:03 PM
mondeomark
Sep 28, 2015 06:28 AM
jonnyenglish
Sep 21, 2015 07:31 AM
Neil Clark
Sep 8, 2015 07:06 PM
hopper350
Sep 4, 2015 12:53 AM
