FAO chummer - guide to fit rear 1/4s
Old Jan 24, 2005 | 01:02 AM
bassboy's Avatar
bassboy
Default FAO chummer - guide to fit rear 1/4s
hi chummer, heres the pics for the rear quarters...
ull begin with this
first take off the c piller and b piller plastic panels (the ones which have the front seatbelt and rear seat belts on) then you need to get the existing quarters out...easily done...just use your foot or get someone to push the window out from the inside while your gently easing the rubber out with a screw driver or something...its harder to explain than it actually is doing
ull be left with this
next put the rubbers into the window frame
then bring the new window into place...you may want a friend to help at this point as it can get tricky...line up the rear bracket first into the 2 holes that are already drilled for you
then line up the front two...you may or maynot have holes drilled there already...if you dont...then line up the window while someone is still holding the window from the outside and then drill 2 holes...one per hinge
screw everything down...and there you have it
bassboy
Old Jan 24, 2005 | 07:55 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Nice one fella. Maybe you or one of the mods could add this into the FAQ forum??
Old Jan 24, 2005 | 08:39 PM
chummer's Avatar
chummer
cheers BASSBOY it's well apretiated!!
top geeza!!!
Old Feb 7, 2005 | 12:08 PM
Hartyboy's Avatar
Hartyboy
Got a pic of the screws that hold it to the body as i dont have any better still do you know where i can gt some from
Old Feb 7, 2005 | 12:14 PM
bassboy's Avatar
bassboy
harty boy...on wat side? the c or b pillar?
bassboy
Old Feb 7, 2005 | 12:16 PM
Hartyboy's Avatar
Hartyboy
both
Old Feb 7, 2005 | 12:17 PM
Hartyboy's Avatar
Hartyboy
and one screw cap missing
Old Feb 7, 2005 | 12:22 PM
bassboy's Avatar
bassboy
right, the ones on the c pillar were these
http://img.photobucket.com/albums/v9...aisakhi019.jpg
and they came with my rear brackets...the ones on the b pillar are just normal selftap screws..
if you have difficulties getting the screws just use self taps mate...its the easiest way
about the screw cap...ask paul r if he's giving some away...he is stripping all the interior out of his S1...but im not too sure if he'll give those bits away
bassboy
Old Feb 7, 2005 | 12:28 PM
Hartyboy's Avatar
Hartyboy
I'll just nick some bolts and screws from work then lol Cheers mate.
Oh yeah also how do you tighten up the bolts that go through the glass did you just thread a bolt into the end of it and use a spanner
Old Feb 7, 2005 | 12:31 PM
bassboy's Avatar
bassboy
whatever you do dont take the caps off on the outside of the glass...one of mine aint sat properly ever since while the window is out...put the brakets onto it and hand tight them from the INSIDE screws...line up the window and then when everything is screwed into place and the window is on...tighten them a little more as they are pretty hard to do as the outer and inner part can spin (still will be tight though so no worries about them falling out )
bassboy
Old Feb 7, 2005 | 12:35 PM
Hartyboy's Avatar
Hartyboy
Cheers mate sounds easy bet i fook it up though lol.
Its one of the rubber internal caps im missing if anyone has one
Old Feb 7, 2005 | 12:37 PM
bassboy's Avatar
bassboy
its easier than it sounds mate..you can have it done in about 20-30mins!
bassboy
Old Feb 7, 2005 | 12:38 PM
Hartyboy's Avatar
Hartyboy
Better get a mate round to help remove the old glass
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
muz
Aug 1, 2015 06:48 AM
