Reusing engine bolts
Old Sep 10, 2010 | 12:16 PM
Craigorypeck's Avatar
Craigorypeck
Default Reusing engine bolts
Hi, I have arp bolts on the conrods and the head has nut and bolt kit I can reuse but the main bearing cap bolts are normal items I think can these be reused?
Many thanks.
Old Sep 10, 2010 | 12:45 PM
Craigorypeck
It says NEDUR 110 on them if thats any help?
Old Sep 10, 2010 | 12:59 PM
chaffe's Avatar
chaffe
Turbocharging Technician
yeah never had any problems re using main bolts, as long as they are damage free will be fine
Old Sep 10, 2010 | 01:48 PM
Craigorypeck
Thanks. Is 100nm torque right for these?
Old Sep 10, 2010 | 04:01 PM
chaffe's Avatar
chaffe
not sure mate, what engine? sounds about right
Old Sep 10, 2010 | 04:38 PM
Craigorypeck
It's a YB. Have them done and all now. Cheers
Old Sep 10, 2010 | 05:11 PM
mattman1234's Avatar
mattman1234
they said they could when i asked,but for what they cost i replaced all mine.peace of mind
Old Sep 10, 2010 | 05:32 PM
NO, con rod bolts on the YB are stretch bolts, would be a gamble imo, stud and nut kit fine though.
Old Sep 10, 2010 | 05:36 PM
DAN400's Avatar
DAN400
tabs i think he was on about useing the main cap bolts again
Old Sep 10, 2010 | 08:20 PM
Craigorypeck
Tabetha the con rod bolts are ARPs, reuse? I have them in now with a bit of grey grease on them and tightened to 60 ft/lb.
It was the mains I was on about first of all.
Old Sep 10, 2010 | 08:28 PM
GARETH T's Avatar
GARETH T
the technical answer is "unless you know they havent been passed there yield point you shouldnt reuse" but to know this you really need to know the length of each bold before they was first used.
Old Sep 10, 2010 | 08:32 PM
Craigorypeck
Thats what I was thinkin... Any idea of the normal ARP bolt length anyone??
Old Sep 11, 2010 | 05:57 AM
GARETH T's Avatar
GARETH T
you cant just take a standard length, as they all very from factory. you need to measure to the nearest 10 micros
Toms Grende
13
Aug 22, 2015 03:39 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
track.focus'd
Aug 12, 2015 05:53 PM
