4x4 Fuel regulator adaptor
Old Sep 9, 2010 | 02:40 PM
FlashRS's Avatar
FlashRS
Default 4x4 Fuel regulator adaptor
Hi, I want to use a stand alone fuel pressure regulator, I ordered a adaptor but it does not fit my rail, does anyone on here make them???
Old Sep 9, 2010 | 03:21 PM
muz's Avatar
muz
Wye Valley Hardcore
I've just had the same problem. Ordered a Sytech one from eBay and it doesn't fit.
Old Sep 9, 2010 | 06:37 PM
A adaptor could be made fairly easy, but would need either a existing fitting or detailed drawing.
Old Sep 9, 2010 | 07:26 PM
FlashRS's Avatar
FlashRS
Got mine from "fuelpumpsonline", rang them, they just wanted to refund me, not sort out another one! I even sent some pics to explain the problem, was told that they have been sending these out for years for a 4x4 saph, no way will it fit.
Just want to find one asap!
When the O ring is in, there is a 1 inch gap before the flanges meet!!!!!
Old Sep 10, 2010 | 08:25 AM
muz's Avatar
muz
Wye Valley Hardcore
Same problem, they just wanted to refund me rather than help find me one that fits.
Old Sep 10, 2010 | 08:48 AM
ian sibbert's Avatar
ian sibbert
Cant you just slot two pieces of 6mm id solid thick wall aluminium tube and use some longer bolts, or cut off the flange and have a -6 fitting silver soldered in...
As long as it holds the 'O' ring in place it will seal.....
I prefer aeroquip fittings on the fuel rails myself, I dont like push on type connections on high pressure fuel lines...
Old Sep 10, 2010 | 09:10 AM
muz's Avatar
muz
Wye Valley Hardcore
Defeats the object of buying an off the shelf adapter really. I think it's the route I will take, just thick it will look a bit bodged.
Old Sep 10, 2010 | 05:39 PM
I can help if you pm me, sending bits special delivery you're only talking 3 days max, pm me if wanted.
Old Sep 10, 2010 | 10:29 PM
FlashRS's Avatar
FlashRS
PM sent!
Old Sep 11, 2010 | 08:26 AM
I got your pm, just awaiting my infraction for "advertising" on this thread trying to help someone out, it's not allowed, it seems, got one on best brakes thread for mentioning that I had a bit if they wanted to buy it, even though they started the thread.
Old Sep 12, 2010 | 08:36 PM
FlashRS's Avatar
FlashRS
Dont care about the politcs, just want to get my car sorted!!!!
Old Sep 13, 2010 | 01:59 PM
I've just now printed the piccie out on A4, and will pop in in the morning and see what he says, he may want a 4wd rail so it's exactly right but should be able to get one of these in the morning as well.
Old Sep 13, 2010 | 07:00 PM
FlashRS's Avatar
FlashRS
Smile Adaptor
Many thanks !!
Old Sep 14, 2010 | 07:54 PM
Hi,
I showed him the pic today, he said no problem to remove bracket from the hex bit and reweld(tig) in correct place, so fits perfect, wants rail and reg, £10-£15.
Pm me if wanted.
JK12
33
Apr 26, 2021 12:09 PM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
kevin36
Sep 8, 2015 12:23 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
