Whine from engine Comp?
Old Sep 7, 2010 | 08:18 PM
zannyUK's Avatar
zannyUK
Default Whine from engine Comp?
Hey,
I've got a 07 Plate Focus Zetec 1.6
When I start car from cold, everythings OK. But after driving for 10mins, at a standstill and in Neutral I'm hearing a highish pitched whine/hum inside the car.. prob coming from under bonnet. It increases in pitch as you rev.
Checked all normal stuff: fans off, aircon off, watertemp gauge normal at midway.
Could this be alternator, or accessory belt problem? How could I narrow this down?
Thanks
K!
Old Sep 8, 2010 | 08:55 AM
Likely to be the alt, next time it does it put the heated lecky rear window on and other lecky bits see if the note changes as the alt is loaded up, another thing you can do is disconnect the auxillary(fan) belt and run for a short while say 20-30 secs.
Old Sep 8, 2010 | 10:05 PM
zannyUK's Avatar
zannyUK
Cheers... I'll have a look and let you know
Old Sep 10, 2010 | 08:03 AM
mikeross's Avatar
mikeross
I did this when I had that problem before when I just installed some ford oem parts. My uncle taught me this. I started the engine and opened the hood; then I took a piece of wood about 2"x2"x2' and I touched one end to various engine components(power steering pump, water pump, alternator, ac compressor,etc) while touching the other end to your ear. sound moves through the block of wood faster than air, so when you touch the component making the noise you should be able to hear it much louder through the block of wood. But keep this in mind: do not stick the block of wood in any moving parts
Old Sep 11, 2010 | 07:18 AM
DannyP's Avatar
DannyP
Keep up
if neither of them clutch thrust bearing?
Old Sep 11, 2010 | 10:16 AM
zannyUK's Avatar
zannyUK
Thanks for the input so far guys.
Update...
Doesn't seem to be alternator. If it was the clutch thrust bearing, would the noise alter when I pressed the clutch in? (it's a manual gear box)
Cheers!
Old Sep 11, 2010 | 11:52 AM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
My 1.6 does this, but it's the clutch release bearing I think, as it stops when I push clutch down. Although, mine makes so many noises, I don't worry about that one
3drRich
Sep 13, 2015 07:32 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Ben26
Aug 27, 2015 08:56 PM
ekjim
Aug 17, 2015 08:57 PM
MadsBL
Wheels and Tyres
Aug 6, 2015 10:04 AM
