s2 rs turbo cut out and will not start
mk4 s2 rs turbo escort
can anyone give advise on following issue,
whilst driving car cut and and will not restart, have replaced coil,cap,and leads but still not starting, fuel pumps kicking in and engine turning over, i have checked spark and dont have it at king lead, when checking feeds to coil there only seems to be negatives and no positive?
im not very technical so any help would be much appreciated!!
thanks
thanks
afternoon all
thanks to all that responded, it turns out the alarm box had gone faulty so it was not switching 12v to coil when ignition switched on, once alarm box replaced started first time
thanks again
thanks again
afternoon all,
i have just give it a run for first time since fixing it and it has done the same cut out and lost its spark, i have rechecked 12v feed and it is there but the coil was red hot(brand new coil), this is going to seem like a stupid question but the 12v feed goes to the black plug should this go onto the + or - connection on the coil? if they were the wrong way round would it start??? like i said before i am no most technical person so all help would be much appreciated
thanks for looking
thanks for looking
track.focus'd
Aug 12, 2015 05:53 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
