a little correction work
Old Sep 4, 2010 | 07:44 PM
ivan's Avatar
ivan
Default a little correction work
the car has took its toll of supermarket trolley hits and the next door mowing his lawn and flinging a stone into the drivers door, plus some neglect during polishing up at shows so I been busy doing a little correction.
some wet sanding on the drivers side doors after touching up with paint
stone chips on the bonnet
all corrected out with the Megs 220 using a Sonus 4" spot pad and SSR 2.5 swirl and scratch remover
bonnet after
Then the whole car has been gone over with the megs 220, a lake and country orange pad using Lime Prime to get rid of the swirls
swirls on boot top
and after
all finished off with a coat of HD wax
Also re-painted all brake calipers
In all about 12 hours work
Old Sep 4, 2010 | 08:56 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
What did you do with the stone chips mate, just touch up with colour then wet sand back then use ya megs 220 to cut then polish out the swirls and blend it all in ?
Dave.
steerfromdarear
28
Jan 29, 2016 06:14 PM
3i Jim
Nov 20, 2015 05:12 AM
yawiejon
15
Aug 9, 2015 06:36 PM
