Capri Engine Conversion
Old Sep 1, 2010 | 12:51 AM
Tee_1's Avatar
Tee_1
Default Capri Engine Conversion
Hi chaps, I've got a '77 mk2 Capri and looking for another lump cos I need more power! Never done an engine change so quick few questions:
1. What would you recommend best engine would be to put it, something that won't require any mods just drop in
2. What other running gear would I need to change i.e. I'll obviously have to get the 4 spd gearbox changed to a 5spd I'm thinking from a later mk3, what else..?
Cheers for any help guys
Old Sep 1, 2010 | 01:03 AM
jon@work's Avatar
jon@work
what engine have you got ?
what's your budget ?
power target ?
Old Sep 1, 2010 | 01:17 AM
Tee_1's Avatar
Tee_1
1.6 in there at the moment
Basically I dnt mind spending about Ł1k all in for everything incl. whatever running gear I need to change
looking at about 200bhp
Old Sep 1, 2010 | 01:48 AM
jon@work's Avatar
jon@work
you'll struggle to get 200 brake for a grand
Old Sep 1, 2010 | 03:28 AM
Tee_1's Avatar
Tee_1
Ye seen u've basically shattered my plans in one twist of your rod. Hit me with numbers what we talking for my budget? Or what are we talking for my target bhp..
Old Sep 1, 2010 | 11:42 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
24v cossie V6, 200bhp
Just sold a complete sapphire with a 24v engine, MT75 gearbox for Ł600.
Steve
Old Sep 1, 2010 | 11:54 AM
scoby_hugh's Avatar
scoby_hugh
For around 2.5 k u cud buy a sierra cos with yb, and more power is easy to extract, then sell all the spares and you could be nearer your target. Yb lump goes on pinto mounts not sure about xflow though?
Old Sep 2, 2010 | 05:34 PM
Tee_1's Avatar
Tee_1
Right chaps I've decided before taking the big plunge I'm gonna try to refine my current 1.6. My clutch is slipping so that is making a big difference to performance. These are my plans:
Skim flywheel
New quality clutch
4 branch manifold
Twin Weber Carbs
Clutch aside do you reckon this should make a noticeable difference?
Also in regards to the Weber carbs does it make a huge difference if they're second hand and should I be running 40's or 45's. Also what's best place to look for them..? Ta
Kyle Langford
27
Aug 5, 2019 07:54 PM
Vacuman
16
Sep 3, 2015 06:26 AM
41
Aug 7, 2015 08:58 PM
