Cosworth battery
Old Aug 31, 2010 | 06:15 PM
jason_nike's Avatar
jason_nike
Default Cosworth battery
Hi All,
The cossie seems to have killed another battery.
Or to honest the battery has killed itself.
It was another halfords battery which are crap, I disconnect the battery when car in the garage and reconnect when using etc.
The batteries last 12 months then give up, and as I cant find the receipt they wont exchange it.
So now gotta buy a new battery, so where is the best place to get one without paying a fortune ??
Old Aug 31, 2010 | 06:44 PM
www.carbatteryshop.co.uk
VARTA BLUE is what you want 095 is the biggest that will fit in the std tray, mine when left with the tracker and the cat 1 going will still start after 4 weeks without a problem.
My last varta lasted me 11 years.
Old Aug 31, 2010 | 07:01 PM
damien roe's Avatar
damien roe
i totally agree i had one in my van for 8yrs
Old Aug 31, 2010 | 07:24 PM
Not the cheapest but with std 5 year warranty, and pretty much always lasting longer well worth the money, I was lucky and got a "new" old stock one, same warranty etc for Ł50 cash for a 72ah one, biggest I could get in the tray, but now being relegated to the boot!!
Old Aug 31, 2010 | 07:37 PM
jason_nike's Avatar
jason_nike
Thanks Tabetha for the advice.
Varta sounds good, but cant find type 095!!!
Old Aug 31, 2010 | 07:43 PM
cossieclive's Avatar
cossieclive
i work for ahem.......motorworld!! we sell yuasa batteries these are good batteries. over the years we have tried several companies but have ended going back to yuasa. they are the biggest battery company no one has ever heard of!! im not sure if they still make an 095 as a lot of companies are dropping the ford fit, however i do have adaptors. or you could do what i did and change to round terminal then you have multiple choices. i would recommend an 075 or the more expensive 096. they both high power batteries and are of a low maintanence, be careful with maintanance free even though they sometimes have 5 year warranties on them they rarely last. one question do you keep your car garaged etc where there are mains power? my cossie can be parked for months at a time and i use a trickle charge which plugs directly to the mains, it keeps the battery topped up but not over charges them. motorworld sells them too and i have fitted a q/r plug on mine too. im afraid all retailers will insist on the receipt but did you pay by card? if you can prove you spent money at halfords to that amount with a bank statement etc they will honour your warranty as long as you dont say the car is parked for long periods at a time which will invalidate the warranty as its seen as neglect im afraid. find proof even if you know it was for something else, as long as it is of similar value still try. halfords can be quite relaxed about warranties as they dont like bad publicity, i used to run the parts section in halfords 11 years or so ago and have replaced batteries that way!
i dont know if there any motorworlds near you and if they are any good too. we have very good shops and very bad shops! but if you buy a battery there and a trickle charger im sure they will offer you some discount.
a tip for everyone with batteries and warranties. when you buy the battery get the receipt and laminate it then stick it on the back of the battery, then if you have any problems you have the receipt!!!!!
Old Sep 1, 2010 | 01:54 PM
Yuasa is indeed a excellent make, have used these on m/bikes myself, I had 100% confidence until they supplied me one with a different battery number on the top to the front, if that wasn't odd enough the top + and - marking were the opposite way around to the case markings, could have been a expensive job if I'd connected it.
You shouldn't use a trickle charger for storage purposes, but I assume you mean a cyclic or conditioner charger, LIDL were doing a excellent one for Ł15 a few months back, use this myself on a caravan, even revives(most0 old dead batteries that std chargers won't touch.
Old Sep 4, 2010 | 12:55 PM
jason_nike's Avatar
jason_nike
Just bought a battery from the link below.
Square bolt tops, 4 year warranty, 2 day delivery
http://www.alpha-batteries.co.uk/buy.../prod_141.html
JK12
33
Apr 26, 2021 12:09 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
FordJonah
Aug 22, 2015 08:31 PM
Aug 14, 2015 07:29 AM
