where to connect oil temp gauge-fiesta
Old Aug 26, 2010 | 05:16 PM
Drag_steer's Avatar
Drag_steer
Default where to connect oil temp gauge-fiesta
Is there any other option to connect oil temperature gauge on fiesta st except sump plug and sandwitch plate? car is fiesta st... I mean if there is sensor for oil temp allready somewhere.
Old Aug 27, 2010 | 10:05 AM
Very much doubt there is a dedicated place, but you can always use the oil pressure warning light sensor hole using a "T" piece.
Old Aug 27, 2010 | 04:27 PM
Drag_steer's Avatar
Drag_steer
ok, but I want oil temperature not oil pressure
Old Aug 27, 2010 | 06:19 PM
Yes that's fine, it will get covered in oil and reflect the temperature that it is at, doesn't matter about being under pressure.
Old Aug 27, 2010 | 06:28 PM
RichieST's Avatar
RichieST
These use paper oil filters don't they, so not sure if you can get a sandwich plate? Somewhere where its in the flow of oil would be best, T-piece might not give an accurate reading of temperature.
Old Aug 28, 2010 | 09:45 AM
Liquid(oil) conducts heat very well, in the oil pressure switch position it will give a truer temp reading than in a sump subject to airflow, and that's before it is compressed by the oil pump and picked up more heat.
Old Aug 29, 2010 | 03:34 PM
Drag_steer's Avatar
Drag_steer
thank you Tabetha. I will try to find where is that place where is the oil pressure sensor...
TPM961
Jan 15, 2018 10:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Brickhouse
Sep 21, 2015 11:00 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
