Engine change?
Old Aug 25, 2010 | 06:45 PM
ZT_Craig's Avatar
ZT_Craig
Default Engine change?
Ok well this is my first post on this forum, normaly a member of ZSOC but recently sold my Zetec-S to get an older fiesta and turbo it eventualy.
I bought a Mk3 Fiesta with a Rs Turbo body kit and a Fiesta 1800i engine in. It runs a dream but I have always wanted a 2.0 ZT. Basicaly my questions are:
which mounts do I need for engine, and both gearbox mounts?
which ecu/loom/key do I use if im putting a blacktop zetec lump in?
All information will be greatly appreciated. I eventualy want to get it Turbo'd with ALO of INTERNAl work etc but im sure these questions will start me off.
Thanks for reading, look forward to seeing some replies
Old Aug 25, 2010 | 07:16 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
as your fiesta all ready has a 1.8 silvertop zetec i would advise you dont use a 2.0 blacktop but a 2.0 silvertop from en early mondeo as it will bolt in with no problems
you will be able to use all the mounts ect off your engine
as for the ecu/loom ect ect as your going to turbo it you will need some kined of after market managment so i would not worry about the coded key ect ect
any more help please ask
Old Aug 25, 2010 | 10:21 PM
ZT_Craig's Avatar
ZT_Craig
So could I run the 2.0 of my current loom and ecu etc? Just bolt the engine straight in? Manifold etc will all fit yes?
Which management system would I be looking or are here lots to chose from?
Cheers for the reply
Old Aug 25, 2010 | 10:27 PM
clarke5700's Avatar
clarke5700
it has been done yes. due to the fact that your engine uses an air flow meater fitting the 2.0 engine the ecu will compensate the fueling its not ideal tho.
i have a brand new m-tech v4 for sale as seen hear
http://www.mtechautomotive.co.uk/eng...gement/v4-ecu/
JoeyBoyden
Jan 4, 2024 02:36 PM
cameron2
Aug 25, 2015 07:18 AM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
ekjim
Aug 17, 2015 08:57 PM
