Yet another issue..
Old Aug 21, 2010 | 05:58 AM
VEEDUBBED's Avatar
VEEDUBBED
Default Yet another issue..
This time i'm baffled.
Right,my car starts frst time off the key,injection system is the classic Web/Mar. L8 system,chip is original from factory.
The problem is that the ecu is getting hot,i mean hot as in a mug of fresh boiled tea!,same thing is happening with both system relays,almost too hot to touch.
WTF is going on here?
When first started the components are fine but after a few miles bingo.
I've never come across this problem on any Weber managed car.
The ecu is located right in front of the nearside headlight so it's not engine heat related and both relays are hotter than the ecu.
I'm loosing patience.
HEEELP
Old Aug 21, 2010 | 01:06 PM
martysmartie's Avatar
martysmartie
It sounds as if something could be shorting causing the problem.
The ECU surely should be inside the car though?
Martin
Old Aug 21, 2010 | 06:16 PM
VEEDUBBED's Avatar
VEEDUBBED
Hi martin,
Yeah your right about the ecu but my car's not a Ford Cos,it's a Vw fitted with an injection system using components off various cars.
The car runs fine when cold 'cos the relays and ecu are cold but after a few miles it starts to cut out violently and,of course,relays and ecu are frying.
I've got both types of system fitted onto my Vw,Pectel super 8 with GGR mapped chip and an ordinary L8 off a Lancia delta evo-1,i can use both.
This bloody problem is present when using both ecus.
I can't figuer it out,why doesn't the systems fuse blow?,if something was shorting out surely the ecu(s) would have both burnt out by now?.
Almost forgot,i've just finished moving the ecu and relays inside the car,above the fusebox so i'll check again if it was overheating inside the engine bay(were it was originally fitted by me three years ago..).
R5FORD
17
Aug 10, 2009 11:35 AM
Slackbladder
Jun 4, 2009 06:15 AM
S2martin
Oct 27, 2007 11:00 PM
DaveEscos
Oct 15, 2005 06:22 PM
