Help Needed !
Old Aug 19, 2010 | 12:06 PM
gibson_85's Avatar
gibson_85
Default Help Needed !
i'm totally lost when it comes to cars so help needed. driving along and the car just cuts out, got it started again and now it seems fine again, for the last few weeks it has been joltin as i change gear, could this be linked?
cant see any problems
just wondering if anyone knows why this could be
thanks
Old Aug 21, 2010 | 08:24 PM
mad4fords's Avatar
mad4fords
newbie
I wish I could help u, but I need similar advice myself as I may be having a similar problem.... just before xmas my mk1 ford focus, started giving me trouble. Its a 2.0 zetec (petrol) at first the speedo wasn't working and the car cut out for no apparent reason, had the speedo sensor changed and car was ok for a few months. Now the car has started cutting out on me now and again, usually when i slow down and go into 2nd gear (its happened a few times going round corners). I took it to a garage and they got it on the diagnostic computer, they told me my car has some kind of fueling fault, but couldnt pinpoint the problem and said this may not even be the reason for the car cutting out. Have you managed to find the problem with your car? or has anyone got any ideas? In desperate need of help.. thanks
Old Aug 26, 2010 | 03:41 AM
vicreyes's Avatar
vicreyes
I had a similar problem for a long time until I cleaned my fuel tank and replaced the fuel pump, there's a recall for the fuel pump.
Old Aug 26, 2010 | 09:24 AM
Although it may seem a bit OTT, if the car has this fault all the time it would most likely be more cost effective putting it on a rolling road, emissions/fuelling can be watched as any problem develops and would likely give a much better clue for the cost of a 1 hour run.
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
