Cosworth & pinto crank differance
so could you not use the flywheel from the pinto or could the cossie flywheel be modified to accept the pinto crank?
need to know as i have 2 pinto engines waiting to be cossiefied
is there no difference in the ones used for pinto than cosworth
The 205 blocks were selected for there bore tolerance, Cosworth asked for only Grade 2 and 3 so if you look by the dizzy you will see 4 numbers I.E 2222 is a Cosworth block, it will also have YBB then a 4 digit number by the water pump engraved into the block apart from there there is no difference, once you rebore these numbers become totally irrelevant anyway.
Martin
Martin
The difference between a 205 non cossie and 205 cossie block is really not worth worrying about, can use a normal 205 without problem.
The flywheels can be made to fit the "wrong" crank no problem, with some welding/filling and machining.
The cranks will as said directly swap over.
just out of interest im planning on building a high specced pinto for my mk2 would fitting cossie crank and rods be a good idea and would it work ie. the rods the same length
Just get an old smokey joe 205 cossie bottom end and a nice new set of 92-93mm 12.1cr pisons and bolt a big valve big port pinto 8 valve head on it and you have a bullet proof pinto!!Twin 48s a nice ex manifold and 200 hp with the right cam!!!
cheers danny
cheers danny
cheers danny
cheers danny
Or don't overdo the head job and stick with 45's with 36 or 38mm chokes for a vastly more tractable 180bhp that isn't lag city, keeping the std pinto crank and rods which will piss this power all day long and be cheaper than anything cossie wise, a tractable 180bhp is massively better all day long than a always out of the power band 200bhp, been there done that.
I swapped DCOE 48's for 45's DHLA, a better carb by the way, stays in tune much longer, getting vastly better torque curves due to higher air speed through carb, the key is air speed I usually ran with 36mm chokes around 175bhp with piper BP285H cam profile ground onto my std cam, and used longer rocker post bolts with extended long pad followers, otherwise they can rip out!!, only had it once, but a 3 cyl pinto is slow!!
202 block is a late transit block, the number on the end I.E the 2 in this case dictates 1992 in the same way the 0 on the end of a 200 block means introduced in 1990 although this was stronger than the legacy blocks I.E 205 (Excluding YBD 205). People do use them as they are more avaliable and cheaper than the rest I think they have less core plug holes than the 205 though and you can't long stud them.
Martin
Martin
big_Rad
Sep 15, 2017 09:36 AM
James Porter
Oct 28, 2015 12:17 PM
Aug 14, 2015 07:29 AM
202, 205, buy, cossie, cosworth, crank, crankshaft, differance, differences, engines, ford, forged, pinto, size, ybb
