how do we fit mondy st24 brakes to an escort mk6?
Old Aug 12, 2010 | 09:22 AM
jghs83's Avatar
jghs83
can you smell purple?
From: normally dewsbury west yorkshire, but i could wake up anywhere!
Default how do we fit mondy st24 brakes to an escort mk6?
as it says guys and gals,
how would i go about fitting a set of mondeo mk2 st24 callipers, discs and pads to my escort van?
what else is needed? different brakes lines perhaps?
does anything need drilling out like the st170 brake conversion?
thanks in advance
Old Aug 12, 2010 | 01:52 PM
john_d's Avatar
john_d
are these gen. v6 brake or just the 2litre 1's that ford fitted to later 24's?
Old Aug 12, 2010 | 01:57 PM
jghs83's Avatar
jghs83
yeah i think so, but could be corrected. they wer removed from an st24
theyve got 887 & 888 stamped on them
Old Aug 12, 2010 | 02:00 PM
john_d's Avatar
john_d
my 24 has the 2litre brakes, not sure what the stamp number is though.
Old Aug 12, 2010 | 02:03 PM
jghs83's Avatar
jghs83
hmm, thats good to know really, ive read somewhere that they will fit so long as there stamped.
if they wont fit i can always sell them again, theyve got grooved discs and ebc pads.
Old Aug 13, 2010 | 02:20 AM
hillzy2k's Avatar
hillzy2k
check the disc size, ford did mix and match their mondeo brakes, some 2.0s had v6 brakes and vice versa. anyhow, std 2.0 have 260mm dia discs whilst v6s should have 278mm (maybe a smidge bigger but im sure thats about right) either way theyre both bigger than standard escort brakes (240mm) and should offer an improvement.
Something to note that not alot of people do. mondeos, escort turbos,cosworths etc have larger bore pistons on the calipers which when fitted to standard escorts causes longer pedal travel (I first noticed this when putting cossy brakes on a 1.1 fez, it was shocking!!!). to compensate this you will require a larger master cylinder, any mondeo one should be fine as they all run the same caliper bore.
If you want bigger brakes still, calipers from a st170 focus or mk3 mondeo with discs from st170 are good, 300mm!! (mondeo calipers are easier and cheaper to get hold of)
Old Aug 13, 2010 | 07:50 AM
jghs83's Avatar
jghs83
thats some top advice there matey, many thanks.
the disc diameter is the 280mm with the correct "887 & 888" calipers.
the pedal travel is a bit excessive any way on my van as the fluid will need changing (which will be done), soonce it is hopefullt ill have better braking.
ive had a trial fit on some spare hubs ad the only thing i can see i need to do is drill the mounting holes out 12mm and i need souch shorter banjo bolts.
Old Aug 14, 2010 | 03:19 PM
hillzy2k's Avatar
hillzy2k
oh, sorry your right on the drilling hubs to accept m12 bolts and the banjos. forgot that bit. lol. you may need to space the calipers out slightly with a couple of washers to clear the disc too possibly.
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
cossie4x4
Aug 14, 2015 06:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
Aug 10, 2015 12:08 PM
Red_bull
Aug 9, 2015 08:34 AM
