1.8 focus zetec
Old Aug 11, 2010 | 06:40 PM
neely wheel's Avatar
neely wheel
Question 1.8 focus zetec
Hi ust got a 2000 focus zetec 1.8 and the there seems to be no spring tension when using first and second i.e. the lever does not centralize,,5 and reverse return the lever when in neutral,is there a spring that breaks,causing this,cheers
Old Aug 11, 2010 | 07:06 PM
thebigmacmoomin's Avatar
thebigmacmoomin
Its sounds like the spring that attaches to the gear lever is broken. Mine did the same but never bothered me so I left it. A cheap replacement from Ford that you can do yourself from memory.
Old Aug 11, 2010 | 07:10 PM
neely wheel
cheers, will check
Old Aug 11, 2010 | 08:31 PM
RichieST's Avatar
RichieST
As above, return spring snapped!
Old Aug 11, 2010 | 08:57 PM
Csm's Avatar
Csm
Heres what you want and a piece of piss to fit ..........
http://www.fordpartsuk.com/shop/focu...pring_1364.htm
Old Aug 12, 2010 | 07:29 PM
neely wheel
cheers u r right,made temp repair with off cut of brakepipe.
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
little bram
Sep 7, 2015 11:59 AM
