1 prob then another
Old Jan 21, 2005 | 07:04 PM
bigal1978's Avatar
bigal1978
Default 1 prob then another
just took the cossie out all was ok for half an hour
on way home all went tits up
battrey light came on i tho oh altinator shaged never mind
tho i best get home quick before battrey goes flat nailed it and missfired like a twat at about 11 psi
any ideas
Old Jan 21, 2005 | 07:27 PM
foreigneRS's Avatar
foreigneRS
Testing the future
it will misfire on boost if the battery light is on as that means that the voltage is low.
when you have a low voltage, the fuel pump is not delivering enough fuel, the injectors are working less, the spark is weaker - all things that make it mis-fire.
replace the regulator/alternator and it should be back to normal.
Old Jan 21, 2005 | 09:42 PM
bigal1978's Avatar
bigal1978
thanks for ur help m8
yorkie92
27
Sep 22, 2017 05:56 PM
gcfcos
59
Oct 6, 2015 05:04 PM
gcfcos
88
Sep 15, 2015 03:48 PM
ray barker
Aug 7, 2015 09:00 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
