Zetec Crank Sensor Lengths? Anyone measured them?
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Got a Focus ST170 running an aftermarket flywheel and standalone management.
Went to fire it up today after fitting everything and it's a none start.
Quickly identified that i've got a 'blip' of an engine speed signal where it sync's for a split second and then flatlines with 0 RPM.
Measured the crank sensor to 36-1 trigger on rear of flywheel and the air gap is 5.5mm!
The sensor I put in is a brand new Focus ST170 item, i'm obviously now after a longer one to bring the gap down to less than 1mm.
Just wondered if anyone had ever measured any alternative sensors and got any useful part numbers to give me a head start on things in the morning
Cheers Luke,
I'm intending to go hassle the Ford parts guy tomorrow and grab 10 mins on Microcat and try and establish which models share what part numbers etc.
If I can find one 4.5-5mm longer then happy days, alternatively, I can go a little longer and space it away accordingly...
I'm not taking the box, clutch and flywheel off when I can just bolt a longer sensor in
The centre section is only 5mm thick? Serves you right for buying a monkey f/wheel
Going from this Im going to guess there is an early and a late sesnor perhaps
http://cgi.ebay.co.uk/Focus-MK1-ST17...item25592d9b7e
Call him tomorrow and get him to measure... the one above to this one too...
http://cgi.ebay.co.uk/Focus-1-8-2-0-...item2a053c9c85
Triggers are machined in as shown below:
Cheers Luke...
Will start making phone calls in the morning - just up against the clock a bit and wanting a flying start!
Cheers Luke...
Hi Will
Ive got a couple of brand new spare Focus WRC timing sensors from cosworth with rachem covering and deutsch conectors
Should be able to adapt it to fit your engine
Its a puka motorsport spec sensor which are usually silly money
PM me and I'll send you one
Out of all the Zetecs black tops, silver tops I have never come across any different crank sensors or bosses.
Put a straight edge across the back of the flywheel on the crank flange and measure the distance to the trigger wheel. You should be 3.4mm
Simon.
Simon.
There are two different lengths of timing sensors available for the Zetec from Ford, got both at home, not sure what model is which as it is some time ago when I got mine from the local dealer
Senors are all the same length here in the U.S. but the housings have changed some. I have a spare that is "shorter" which would help you. Let me see if I can find it and see how much shorter it is.
DixieTheKid
11
Jun 6, 2020 11:20 AM
mike elsome
Sep 14, 2015 04:08 PM
Si B
Sep 12, 2015 06:49 AM
