e36 bmw lsd's? just from e36's?
im after an lsd for my 328 but curious if they can be taken from any other models other than 328 sport or m3, do and 5 series or anything have one to fit? cheers
not easy to get hence prices high
only source is e36 325 that had it fitted as an aption (rare) or early 328 sport (96/97 pre traction control models).
I've had a lot of these models and only one so far came with an lsd hence its rare to find one breaking with an lsd
M3 LSD will fit straight into your car
M3 Evo LSD will not as it has a bigger case and the output flanges are diferent.
I looked at many LSD options when I was putting together a conversion on my E39 540i Sport and ended up using the M3 Evo LSD/case with an M5 cover and shortened the propshaft by 15mm - Everything else was identical to what I needed apart from the gear ratio was slightly higher so acceleration was improved at the loss of top speed (but the speed lost was past the 155 limiter so never a problem in reality)
I did a massive writeup on the BMW5 forum about it, but the whole shabang cost me Ł500 to do as I was lucky enough to get an M3 evo diff from a breakers for the princley sum of Ł200
si as i keep saying i dont want to be looked @ like a twat when parking etc as is scuffs up the inside tyre lol, i want a proper lsd, if a non evo diff fits i think i know someone who has one too for Ł150
Are you looking to buy one?
I've been offered one today.
Its a bmw with an lsd 1991 525 sport and the lsd diff works (it left 2 nice black lines when I tested it) and its nice and quiet no noise from the diff.
I will be selling the car on but if you want to work something out, with your old diff in p/x let me know.
