mondeo 2001 zetec issue *update*
Old Aug 4, 2010 | 09:37 PM
LHD220Turbo's Avatar
LHD220Turbo
Default mondeo 2001 zetec issue *update*
gents,
2001 plate mondeo, 1.8 petrol zetec (newer shape) developed a problem with jumping when driving, bit like kangarooing through the rev range, but does not do it all the time?
cant use a mates scanner until next week, so any common problems?
i was thinking maybe throttle position sensor or coil problem?
any ideas?
Old Aug 5, 2010 | 06:13 AM
coco16i's Avatar
coco16i
Coil pack mate, common problem on the petrol engine's.
Probably worth sticking in a set of plugs at the same time but fault is almost guaranteed to be the coil pack.
Old Aug 5, 2010 | 11:43 AM
LHD220Turbo
thanks buddy,
i'm selling the car so i think i'll stick a pattern part on, i bet OE ones are expensive
Old Aug 5, 2010 | 07:00 PM
About £40 for oe one, does indeedy sound like the CP.
Old Aug 5, 2010 | 07:47 PM
LHD220Turbo
bit of an update, just used a friends snap on scanner, came up with EGR valve blockage
can the egr really give this amount of kangarooing??? secondly where is it located approx? lastly will brake cleaner be OK to clean it with?
Old Aug 5, 2010 | 08:21 PM
billybigspuds's Avatar
billybigspuds
nice, the egrs on those are a git to get too
Old Aug 6, 2010 | 07:37 PM
LHD220Turbo
bump
Old Aug 7, 2010 | 08:46 AM
Just follow pipes from exhaust to inlet, you'll soon see it, I take it off, as well as the pulse air, gives so much more room around the engine, make sure if removing to keep the EGPDS connected to start with as some default to limp mode if this is removed,
EGPDS exhaust gas pressure differential sensor.
Old Aug 7, 2010 | 09:13 AM
RichieST's Avatar
RichieST
Have a look aswell on the inlet manifold, under the rubber pipe between throttle body and airbox, there's a small yellow ball valve with a black clip thing over it that actuates the flaps in the inlet manifold. These always pop off and will make it run a bit funny! Bit of a bugger to find as its quite small but it is there!
Old Aug 7, 2010 | 06:56 PM
LHD220Turbo
cheers for the advise gents
bit of a story today! going up my friends garage to do a few bits and bobs and it breaks down round the corner from his yard completely seperate problem......basically the fuel pump was buggered, thankfully got another at the local motor factors (£135 lighter)
still have jumping problem, i think its more of a plug/ lead/ coil problem!
bloody cars, i only want to sell the thing, but i'd never sell on a pig so i'll sort it
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
talon1
Sep 15, 2015 10:27 AM
BRAM
Sep 8, 2015 07:11 AM
