Needed
Old Aug 4, 2010 | 11:37 AM
cossie891's Avatar
cossie891
Default Needed
As I can't post in the wanted section where can I get a good 2nd hand 2wd dipstick and tube from?
Old Aug 4, 2010 | 12:09 PM
joffy's Avatar
joffy
SLOW LEARNER
North yorkshire rs spares
01944 710368
V helpful
Old Aug 4, 2010 | 12:20 PM
martysmartie's Avatar
martysmartie
What he ^^ said, his brilliant, unfortunately he had a bereavement, so he may or may not be back at work yet, only one way to find out, his a member on here as well by the same name.
Martin
Old Aug 4, 2010 | 12:47 PM
cossie891's Avatar
cossie891
Sweet cheeRS guys
Old Aug 4, 2010 | 01:13 PM
joffy's Avatar
joffy
SLOW LEARNER
Didn't know that mate, hope all is as well as it can be, pauls a proper helpful chap
Old Aug 4, 2010 | 05:07 PM
If you get stuck it's easy enough to make one, just need the dimensions and depth etc, I have these written down somewhere.
Old Aug 4, 2010 | 08:17 PM
cossie891's Avatar
cossie891
its a tube i need really as the dipstick can be fixed but the tube is bent and too short its had some grinding done on the top
Old Aug 5, 2010 | 06:00 PM
Simple to buy a length of tube and cut to length, if you still get nowhere pm me, could always use a tube slightly bigger and lathe the block part to fit then cut to length.
Old Aug 9, 2010 | 06:28 PM
cossie891's Avatar
cossie891
Pmed lol
Old Aug 11, 2010 | 05:01 PM
Hi,
I measured the dipstick tube from my 2wd today for you.
Outer diameter 10.3mm
Inside diameter 8.15mm
Length 265mm
Markings, measured from the "collar", that is on the dipstick itself and plugs into the tube when inserted fully, minimum mark 405mm, maximum mark 384mm
Hope this helps, the tube is no problem, the inner diameter isn't super critical, so long as dipstick passes through, the outer I could easily lathe down from a 10.5mm or 11mm for you if wanted.
Old Aug 11, 2010 | 05:22 PM
cossie891's Avatar
cossie891
CheeRS Boss I will get straight on it
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
