Is it possible to fit??
A cossy t3 to and erst?
My turbo is knackard and my brother upgraded
his turbo to a t34 so can I use his old t3 as it's
only a few months old when it was taken
off.
I know I'll have to change the exaust housings as
the exaust bolts diffrently.
I also realise that the other bits and bobs will need
to be changed( water oil pipes)
just wanted a heads up before I take a
perfectly good turbo apart.
Cheers John
off.
Cheers John
I will probably be corrected, but i think this is more or less a stage 2 t3 (by most rst standards) with out a 360 deg thrust??? but any how capable of over 230ish brake.
Rob,
Rob,
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
