running problems
Old Jul 21, 2010 | 02:35 PM
ford-escort-rs-turbo's Avatar
In need of .48 turbine
Default running problems
Hi wondering if anyone can help ?
i have series 2 RST and was running fine before and had front end crash its since had whole new front end new rad new intercooler,
now after it was put back together had loads of trouble trying to get it to run correct timming was out and air fuel was way out its now set at 2% and idle fine i can drive the car but as soon as anysign of boost the engine starts spluttering and then sounds like only running on 3 cylinders then it will clear as long as revs are kept below 3000rpm at first i did find that from the accident the actuator bracket had been hit hard and the acctuator was holding waste gate open so adjusted that and that has made it worse as now it will boost to 15psi if i keep my foot down but it will cut right out then back in and splutter and run rough ive run out of idea as ive renewed everything and still cant sort it ?
could the turbo be cracked it was brand new before accident
thankyou in advance
andy
Old Jul 21, 2010 | 07:36 PM
project rs's Avatar
project rs
no your fuel or spark are not right it needs setting up before you melt the engine you need your on boost fuel setting like you needed your idle fuel setting but not sure why they have been touched if you only had a panel crash if no one touched them they all should of been fine, same as timing why has this been touched as could still be out
Old Jul 21, 2010 | 08:30 PM
dont no why they have changed i was told the knock sensor or act temp sensor was playing up so i changed them and also had air leak from fuel distributor as the rubber O ring was split that made big diffreance to the co2 readings and had to changed co% again looks like ill have to see if anyone can set it up for me thanks for advice m8
Old Jul 22, 2010 | 04:01 PM
ive had the car into local garage had timming set up at 8% btdc and co2 set at 2.5% and still the same they had look for air leaks and found nothing that is as far as they would go as they dont know enough about the escort rs turbo to go to deep so im still with this problem ?
The only other thing that has been uprated is the breather system to baileys and a kent cvh 34 camshaft could the camshaft cause these problem if not set up right ? i loosing hope now any help would be great thankyou Andy
Old Jul 22, 2010 | 08:48 PM
project rs's Avatar
project rs
the timing is 12 degrees and you have 2 fuel things to set up one for idle which you've done and there's another one which does you on boost fuel which is the little black/grey box on the fuel metering unit but you really need to know what your doing to set this and some equipment to monitor the results and if the cam is knackered you'd get some erraticness but not normally to the degree your getting, you need the cam timing setting aswell as the dizzy you really need to go to someone with knoledge of them, jano would be my choice down your way he knows his apples
Old Jul 23, 2010 | 11:05 AM
hi who is jano do you have an address or phone number thanks andy
Old Jul 23, 2010 | 11:37 AM
chaffe's Avatar
chaffe
Turbocharging Technician
could it be posibly that metered air is escaping back through the breather you have installed? this would cause it to go mega rich and retarded on boost! just a thought, ive put these breathers on before and never put the return back into airbox as this can cause this type of problem, try venting the breather to atmosphere and blanking off the port in the metering unit, just a thought
Old Jul 23, 2010 | 12:23 PM
hi i did have it so it was breathing to atmosphere and the problem was still there ive since reconnected to airbox
What i dont understand is it was spot on boosting to 20psi with no problems then had a front end crash and now its playing up since the repair the only thing we found is the actuator bracket must of bent as the rod was keeping the wastgate open all the time but all we done was adjust the rod and set it to 15psi and now got these problems im stumped to what it is thanks for advice
Old Jul 23, 2010 | 01:20 PM
chaffe's Avatar
chaffe
Does seem like a strange one, the actuator isnt cracked or split leaking boost? mdoesnt take much of a hole to cause problems, thing is if you sort it you will have to reset your co mixture again mate.
Old Jul 24, 2010 | 04:55 PM
WELL looks like its fueling my co levels are moving up and down like a yoyo it was all set up but still had the problem today i started her up and the fuel is so rich it burns ya eyes so had it redone and it was on 9.8% so was readjusted down after a few reves car cut out and wouldnt start again so he adjusted the screw back and it started again and co was reading -10 so what can be causing the change in the co levels once its been reved a few times the guy didnt have a clue as he cant find any air leaks the vacum on idle is around -8 if thats any help wouldnt it be lower if it was leaking air ? thanks for any help Andy
Old Jul 24, 2010 | 06:56 PM
project rs's Avatar
project rs
possibly a knackered metering unit and as i said unless you know what your doing with theses then your pissing into the wind and it jano at oddkid creations
Old Jul 25, 2010 | 09:40 AM
chaffe's Avatar
chaffe
Ke-jetronic was ok when it was new, but things soon went efi, and remain so today 20 years on! consider maybe converting it to efi with fiesta turbo parts, and programable management like megasquirt or similar, it give you so much adjustability and scope for improvement and further modifications. Ive megasquirted four cars and had great results from them all. Depends if its a car to keep or not, just thinking incase you start spending lots of money on the old k-jet system!
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
