Fuel Lines (HELP!!)
Old Jul 17, 2010 | 07:45 AM
Cossy Mike's Avatar
Cossy Mike
Default Fuel Lines (HELP!!)
Anyone know how to seperate the high pressure fuel line from the regulator to the hard piping that runs along the floor pan??
I need it all off and don't wanna break anything
also the hard plastic piping that fixes into the inlet, it's seems like it's moulded on there.
Old Jul 17, 2010 | 09:33 AM
The rigid pipe is moulded on, only way is to cut it off.
Old Jul 17, 2010 | 09:35 AM
Cossy Mike's Avatar
Cossy Mike
How would I replace/re-mould it then? could I not use the old one?
thanks
Old Jul 17, 2010 | 06:39 PM
The only way I could see you re-using the old bit would be to apply enough heat to soften when removing putting back on, not worth the hassle imo, as pressure goes 10 bar is peanuts, will easily seal with a juby clip or similar.
Old Jul 17, 2010 | 09:31 PM
PAUL S's Avatar
PAUL S
they are removable, there is a special double prong tool to get them off the metal pipe, the prongs slide down into the body and release the clip
Old Jul 17, 2010 | 09:44 PM
cozzy jeff's Avatar
cozzy jeff
like these:
http://www.drapertools.com/b2c/b2cit...78.144.112.167
Old Jul 17, 2010 | 10:54 PM
Moonstone Mart's Avatar
Moonstone Mart
I bought a set of these from our toolman.
Pretty cheap and come in handy too.
You could try and make soemthing yourself - it only needs to push the spring back enough to pull the pipe out.
http://www.ntxtools.com/Merchant/gra.../lis-37000.gif
Mart.
Old Jul 18, 2010 | 07:17 AM
Cossy Mike's Avatar
Cossy Mike
Originally Posted by cozzy jeff
Thems the ones I got but not sure how to use them
The lines and the fuel rail are lying under the car all connected.
Can any one give me any tips please or talk me through it??
Old Jul 18, 2010 | 07:18 AM
Cossy Mike's Avatar
Cossy Mike
Yeah them
Old Jul 18, 2010 | 08:41 PM
steventoon's Avatar
steventoon
They aren't the proper tool, although they may work. I borrowed the proper one from work and have now managed to source one. It cost me around Ł25. I tried heating mine as Tabetha mentions but it didn't work for me. Mike are you in Cornwall?
Old Jul 18, 2010 | 09:59 PM
Moonstone Mart
Did my reply get totally ignored then?
The set cost me less than a tenner and has been used by various people to remove their fuel rails from the fuel lines.
Mart.
Old Jul 18, 2010 | 11:17 PM
Paul_RS's Avatar
Paul_RS
He wants to remove the fue pressure reg from the line though, your tool removes the inlet side.
Don't see why he can't jsut either unbolt the reg from the rail if its 4x4 or just un jubilee clip the reg if its a 2wd and leave the moulded fuel pipe on it?
Old Jul 19, 2010 | 04:33 AM
Cossy Mike's Avatar
Cossy Mike
No mate I'm way up North in Washington Tyne and Wear
Old Jul 19, 2010 | 04:35 AM
Cossy Mike's Avatar
Cossy Mike
Mart.
Sorry mate thought I did reply
I've had a quick look and it is a plastic collar, did'nt want to pull and twist in case I snapped it
Old Jul 19, 2010 | 04:37 AM
Cossy Mike's Avatar
Cossy Mike
As it stands all the fuel lines are on the garage floor under the car connected to the fuel rail (it is 4x4)
I need it all stripped down to polish the rail up as I'm buftying the whole car
I could live with a jubilee clip on the regulator and inlet if I have to cut them off but my main problem is seperating the flexy high pressure fuel line from the hard fule pipes that run under the floor pans
Old Jul 20, 2010 | 10:48 AM
steventoon's Avatar
steventoon
Mike as an exiled Geordie, I can post you both my tools that will do the job your after as long as you post them back to me mate before the end of August!
If you pm me your address I'll post them on Thursday so should be with you for the weekend.
Old Jul 21, 2010 | 10:14 AM
Cossy Mike's Avatar
Cossy Mike
PM sent
Old Jul 21, 2010 | 10:37 AM
steventoon's Avatar
steventoon
ok mate, i'll post tomorrow
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
Dubs44
Sep 19, 2015 06:31 AM
